Old 08-03-2018, 09:03 AM   #1
08 Blast 150mph Loading Light replacement
I am looking for info on how to replace the rear loading/flood lights? They seem to be on swivel bolt but can't access the nut to remove it to replace the lights. I want to upgrade to LED. - I can't even tighten the light housing. TIA
Larryob10 is offline   Reply With Quote
Old 09-22-2018, 09:50 PM   #2
Coachmen Chris's Avatar
I've wondered the same thing. I recently cleaned the lenses but , like you I want to eventually switch the old lights to L.E.D.
I'm going to stop by here again in the future to see what's been done.
If I decide to do this change I'll make sure I take some pictures.
Have a good one..
Coachmen Chris is offline   Reply With Quote
Old 09-22-2018, 10:29 PM   #3
Flood light cant tighten them
Instill cant figure out how to remove the lights or tighten up the light housing, friend just use rtv to keep from being loose???
Old 09-22-2018, 10:43 PM   #4
Oaklevel's Avatar
On our the lights looked the same as the old fog lights everyone was putting on their vehicles a few years back. I never had a problem tightening mine but I have a lot of odd wrenches.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 10-22-2018, 06:46 AM   #5
I can tighten the movement up and down but not the swivel, like my friend said I put rtv around the mount and that seems to be working. I also thin I am going to have to remove the inside wall "trim" above the back door to get to the bolts to remove and install a new LED light i want add a 36" or longer light bar.
light, replacement
