Old 01-15-2015, 03:44 PM   #11
Coachmen Chris's Avatar
Thanks everyone for the input. Took a break from the RV to install grab bars for the wife recently.
Name:	ImageUploadedByForest River Forums1421358204.659901.jpg
I'm not sure what type of bolts I did get. Will look at them later this evening.
Now get camping ! 😛
Coachmen Chris is offline   Reply With Quote
Old 01-16-2015, 05:54 PM   #12
USPS dropped off a package today. Might do some work on the toy hauler this weekend. I think I'm going to lay the plywood down. We'll see..
Name:	ImageUploadedByForest River Forums1421452466.719506.jpg
Now get camping !
Old 01-18-2015, 11:17 PM   #13
Did a small amount of work tonight. Going to be installing the plywood any day now. Just wanted to get part of the floor straight.
Name:	ImageUploadedByForest River Forums1421644505.183885.jpg
Name:	ImageUploadedByForest River Forums1421644532.234886.jpg
Name:	ImageUploadedByForest River Forums1421644548.154942.jpg
Name:	ImageUploadedByForest River Forums1421644567.752921.jpg
Also looked to see if the new bolts were stainless or not. Couldn't tell
Name:	ImageUploadedByForest River Forums1421644631.008318.jpg
Now get camping !
Name:	ImageUploadedByForest River Forums1421644643.223854.jpg
Old 01-18-2015, 11:30 PM   #14
Name:	ImageUploadedByForest River Forums1421645432.104252.jpg
Now get camping !
Old 01-18-2015, 11:53 PM   #15
geotex1's Avatar
You do not want to use those for the ties downs. Those are plain steel machine screws and not up to task because they are not load-rated. Those tie-down actually get a fair amount of load transferred to them when your bike wants to lean. Looking at the construction of those tie-downs, a single Grade 5 cap screw (laymen just call these bolts) through the center hole of the tie-down through trailer frame is more than enough as it would be stronger than the tie-down. The other two holes are usually just lagged or riveted to the decking.
geotex1 is offline   Reply With Quote
Old 01-19-2015, 04:05 PM   #16
I didn't even think about the bolt under a load. Totally slipped my mind !! Thanks Geotx1 , I could definitely have seen more issues down the road because of a bolt not up to par
Old 01-19-2015, 05:19 PM   #17
geotex1's Avatar
Happy to help! Hope you get it back together soon!
Old 01-19-2015, 05:49 PM   #18
Ford Idaho's Avatar
I would use stainless steel carriage bolts in a 5/16th or 3/8 inch diameter.
Old 01-19-2015, 06:21 PM   #19
Taranwanderer's Avatar
I was going to chime in with the "use some Grade 5 Bolts" recommendation, but someone beat me to it. Those machine screws you had would bend like a pretzel, or just snap. Also, +1 on the fender washers, and nylock nuts too. Once it's in place and torqued down, spray the exposed bolt underneath with some black rust proofing paint (like rustoleum or the like) to keep it from rusting/corroding. Looks good!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 01-19-2015, 06:41 PM   #20
vinmaker's Avatar
You have quite a project there.
But I want to comment on your first part of the original post. When I read the first few lines, I thought to myself. Can he not find a way to modify a camper so that his wife can use her chair. Are there no options?
And then I saw that you had purchased a toy hauler and I felt a tear well up. I am so glad you were able to get something that works.
God bless you and your lovely wife.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
