Old 01-15-2015, 02:35 AM   #1
Coachmen Chris's Avatar
Blast 150MPH
Hello everyone. Just wanted to share some of what's been going on in my life.
I used to have a Wildwood TT. Hence my user name My wife has MS ( Multiple Sclerosis ) and can no longer walk. She has to use a power chair. With that I couldn't see holding onto the TT so I sold it.
Here's a pic of my old setup:
So as I was selling my Wildwood my DW and I decided a toy hauler would be beneficial. I could haul either my 4wheeler or Harley and she could use the ramp back door to enter and exit.
With my current TV I couldn't go crazy because of the total towing capacity of my truck. I have a 2005 Toyota Tacoma. Total weight for towing is 6500lbs.
I knew I couldn't afford a new vehicle so finding a toy hauler was going to be a challenge. Especially one I could find in the towing weight range I was looking for.
So it took awhile of searching and I found the toy hauler I thought would work great for us. I ran across this:
It's a 2008 Adrenaline Blast 150mph
So when I bought it I noticed one section of floor felt mushy. The previous owner assured me everything was good. No rott and so forth.
Did mention it had a water leak but he fixed it. :roll eyes:
Took the setup out for a nice vacation in Wisconsin. On the way home I stopped and did a quick look in the back to see if everything was ok.
Open the door and my Harley is leaning up against one of the fold up beds.
Was I PO'D!
In this pic near the red strap you can see the floor tie down has popped out:
Long story short, the bike was ok and I decided that winter was fast approaching so I was going to see if there was rott or what...
Here is some of the process:
Coachmen Chris is offline   Reply With Quote
Old 01-15-2015, 02:42 AM   #2
There was mold under the diamond plate and on the floor. So upon taking the vinyl or whatever type floor it was there was noticeable water damage :
I couldn't believe what I was seeing. So I was over whelmed as to what to do.
With motivation from a good neighbor and friends I decided to fix it.
There was a lot of wood to replace.
Old 01-15-2015, 02:50 AM   #3
So fast forward to today and many , many hours of labor. I'm getting closer to being happy with it. Still have the plywood to lay down and so forth. Here is what it looks like :
Here's a quick vid :
http://vid21.photobucket.com/albums/...uyork1/022.mp4 <<<< Click Here
Old 01-15-2015, 02:57 AM   #4
So one day I was under the trailer and I notice cracks in the frame :
So I'm really irked now I have more stuff to repair.
As I was going over the paper work I was givin, I notice the frame is made by a company named Lippert. So I did a quick google search. Seems like a common problem with that company.
Guess I've got to find a good welder now.
Have a good one....
Old 01-15-2015, 07:46 AM   #5
TURBS's Avatar
Very nice write up with pics!
Unfortunately I think the guy reeled you in on this purchase
Find a reputable welder and get it healed up.
Short as your unit is I'd plate the whole frame and you'll be set.
I hope you get to enjoy it soon!
Old 01-15-2015, 08:26 AM   #6
KD 1's Avatar
I almost bought a used one of these myself. In checking it over I found water inside on the seat cushions & inside the window frames. The owner says he & the wife washed the TH yesterday. #1 it didn't look like it had been washed & #2 why is the interior wet if you washed the outside?
I found a few more small issues but was still willing to buy but he was firm on $8500 for a 10 year old (I believe) camper. I passed on it. I didn't even look underneath.
But you have made lemonade out of the lemon it seems & it is looking good.
Just curious, what or how did you attach the tie downs to the floor?
KD 1 is offline   Reply With Quote
Old 01-15-2015, 08:27 AM   #7
Salt Shaker's Avatar
When it's all said and done you'll have a rig much better than the factory ever thought about putting out and you'll have the confidence to tie you bike down without worrying because you built it right.
Is it possible to run a metal plate to the frame for your floor tie downs? Might take a little fab work.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 01-15-2015, 04:02 PM   #8
The floor tie down had one bolt that goes through the center. Then on the top and bottom there are small lag type bolts that hold it also.
The middle bolt goes through part of the frame. The problem with that is, the bolt sticks out in the elements underneath the RV. The bolt then gets rusted and it no longer can hold the tie down properly.
Name:	ImageUploadedByForest River Forums1421355528.784913.jpg
I'm going to put new tie downs with new bolts and nuts so hopefully it doesn't pull through like it did.
Name:	ImageUploadedByForest River Forums1421355601.118438.jpg
Old 01-15-2015, 04:14 PM   #9
geotex1's Avatar
That's quite a project you have on your hands! The frame can be fixed, but make sure your welder has credentials for structural repair! Mending plates are in order as well to reinforce. That's not a stainless bolt is it? Hard to tell from the picture. If it is, don't use it! Instead get yourself some a proper grade steel fasteners with yellow-zinc or an ultra-coat anti-corrosion coating on them. You can always add some undercoating, wax, etc. where they are exposed below deck for more protection. Good luck with your project, and I hope you and your wife get out camping with it soon!
geotex1 is offline   Reply With Quote
Old 01-15-2015, 04:18 PM   #10
TURBS's Avatar
Use fender washers on the bottom
