03-26-2019, 08:49 AM
Cable/TV Coax Schematic
Rig: Coachmen Catalina Trailblazer 26THS.
Anyone have a schematic of how the Coax cables are routed on this rig?
03-26-2019, 08:52 AM
Probably not.
Wiring/plumbing schematics are few and far between from the factory.
What year?
Did you contact the factory by chance?
Days Camped: '16=46 ☼ '17=30 ☼ '18=51 ☼ '19=53
03-28-2019, 06:32 AM
Sorry, it's a 2018.
No, I haven't contacted the company. Not even sure how to.
03-28-2019, 02:27 PM
Originally Posted by Lordlindsey
Sorry, it's a 2018.
On Forest River's web site is a contact page.
Navigate (click the link I provided below) to the brand you have and wala!
Forest River Contact Page
03-28-2019, 04:45 PM
Can never get cable TV to work
03-28-2019, 05:23 PM
Same here. Dealership I purchased from is completely inept.
03-29-2019, 02:29 AM
Are you turning the amp off on the main coax panel if you have one?
If your rig uses the same wire to feed the TV for both OTA Antenna AND Cable, there is usually a wall plate with the cable that hooks to the main living area TV. On that plate, there is usually a very small button and a small light.
Hook your cable up to the camper, and then press that button to turn the light off and see if that gets your cable working. Light on is OTA Antenna, Light off is cable. Generally. Campers now a days with some of the new antenna systems are doing things a little different sometimes but that used to be a semi-standard way it worked.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
03-29-2019, 06:35 AM
When hooked up to cable, I'll get a very fuzzy, unwatchable, picture with the amplifier turned off.
I suspect the cable is shorted to ground or something.
I say this because I had a 110v outlet shorted on day one.
03-29-2019, 07:07 AM
Lacey's Spring, AL
...are you sure it's not the park's cable itself?
test this by using a coax cable and going directly from the park cable connection to a TV itself....
03-29-2019, 07:16 AM
Yes, I've done that and everything works fine when you bypass the camper itself.
After you've done this ^^^^^ and confirmed you actually have a good cable signal at the post AND that your TV is able to receive cable - your next thing to check is to check for correctly installed cable end fittings at every place you CAN access. The first place to check is the back side of the little antenna amp/outlet wall plate.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
03-29-2019, 07:22 AM
Lacey's Spring, AL
I found early on that a splitter below our kitchen cabinets, leading to the bunk tvs, was actually 'broken'... it can happen, especially where coax connections happen in a slide where things 'move'...
you have a wiring issue somewhere...it's not uncommon.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
09-30-2019, 07:20 AM
Update: had to tear into the cabinet area where the TV amplifier is. Found splitters with loose connections.
Not happy to have to tear into it like I did.
09-30-2019, 07:49 AM
You are going to find that is part of R/V ownership.
Have you ever visited a R/V factory or watched any of the YouTube videos of the assembly line process? If so, you'd wonder how anything works.
A 'good' dealer can be advantageous too.
Good ones would have checked all that (and more) BEFORE you purchased it.
Sorry yours was inept.
Often times (depending on your skill set) picking a dealer is as important as picking a R/V.
