Old 11-26-2019, 02:58 PM   #1
Change oil drain access missing on adrenaline
2019 adrenaline. Went to change oil in onan 4000 eq generator
Could not find drain plug. Watch several u tube videos.
They all showed a small plate with 2 screws. Remove plate and you have access to drain plug . Nothing like that underneath. I assume Forest River cover it up putting undercarriage (wood). I had to buy pump to get oil out. Has anyone had this problem?
Adrealine is offline   Reply With Quote
Old 11-26-2019, 05:49 PM   #2
Bill and Gail's Avatar
What type of rig do you have? I just changed the oil in mine. The plate is a small oval shape, about 3 inches. Mine is slightly above the run of the exhaust pipe. Just look along the exhaust pipe, underneath. Move the plate, and the drain plug is above it. My plug uses a 12mm socket.
Bill and Gail is offline   Reply With Quote
Old 11-30-2019, 12:20 PM   #3
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 12-02-2019, 05:35 PM   #4
Check again underneath generator and by exhaust. Watch u tube videos. They all show a plate underneath with 2 screws. Remove that and you can access drain nut. Not on mine. They must of cover my drain plug.
Old 12-02-2019, 06:32 PM   #5
SlowrideHD's Avatar
Good question for the dealer to answer.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 12-02-2019, 08:01 PM   #6
now that you got the pump do you need the drain screw? I used to change oil on my VW jetta TDI PD with just the pump all the time.
2019 Forest River Forester MBS 2401R
TowPro is online now   Reply With Quote
drain
