Old 04-22-2019, 08:55 PM   #1
Freedom Blast 17 Cycle Wheel Chock...wheeew
So I called Coachmen and not a lot of help with wheel chock attachment other than ...Water tanks run down the middle over axles...
Well that was bad news to me....So I did an exploratory cut in the under belly and to my surprise found a cross member and a 6 inch space across the width of the trailer right where I am going to mount the Condor quick-attach....
So relieved this is doable....
Can do the project thru an 8" x 8" hole and then seal the under belly plastiboard up ...done
myssrhl is offline   Reply With Quote
freedom, wheel
