Old 09-12-2012, 09:05 PM   #1
timbo7's Avatar
Toy Hauler & Tongue Weight
Been pulling my toyhauler with kayaks in cargo area for 4 weeks. Decided to put the Harleys in and try and get hitch and tongue weight right. Let me give some numbers about my trailer:
33'-6" long
dry weight 6798 lbs.
7000 lbs. w/pots pans & clothes
1020 lbs. tongue weight
14.57% tongue weight
9000 lbs. w/ Harleys loaded & ride gear
700 lbs. tongue weight
7.7% tongue weight
Reese 1200 trunionbar W/D hitch with Dual Cam Sway control
Think my tongue weight with the Harley's ia a little too lite. Talked to Coachmen about tongue weight %, was told to pull it down the road and see how it handles. I'm kinda scared to pull that much down the road as an experiment. Talked to dealership owner today, he said he would also pull it to see how it handles. I thought that I should have a min. of 10% tongue weight and max. of 15%. What you think? Dealer also told me that the WD hitch tries to get tongue weight to 0%, and that the lighter the tongue weight the less number of links that will be hung on WD bar.
Timbo7
2013 Coachmen Freedom Express Toy Hauler
2007 Tundra Crewmax
timbo7 is offline   Reply With Quote
Old 09-12-2012, 09:18 PM   #2
You are right that you want around 10-15% on the tongue. But every setup is a little different, so it's not bad advice to go for a brief, careful tow and see how it handles. The rest of what you're dealer is saying I don't get.
You could also try moving your load forward a bit. Even a foot can make a difference.
I'd be most concerned with how you have 2000 lbs of cargo secured back there - you definitely don't want anything moving around while you are underway.
crasher is offline   Reply With Quote
Old 09-12-2012, 09:29 PM   #3
timbo7's Avatar
My toy hauler has an enclosed cargo area or garage. the harley's are as far forward as possible because of the wall. I do have them staggered 4". was wondering about using tractor siutcase weights to help achieve the min. 10% tongue weight. Just seems a little wasteful to have to add weight that has no other benefit other than tongue weight, but if that is what I have to do, I'll do it.
Timbo7
2007 Tundra Crewmax
Old 09-12-2012, 09:32 PM   #4
I'd be really reluctant to carry extra weight for no reason - especially dead weights.
Where is your water tank? If it's ahead of the axle you could just fill it up. 8 lbs a gallon. At least you can use the water. Same if you have a built in gas tank.
Old 09-12-2012, 09:43 PM   #5
timbo7's Avatar
fresh water tank rest on axles and goes towards back of trailer. Tried filling Gray water and Black water (32 gal. each ) to see if that helped. Both of these tanks are forward of axles. Filed 60 gals. of water into these 2 tanks, but only benefitted 150 lbs. of tongue weight.
Timbo7
2007 Tundra Crewmax
Old 09-12-2012, 09:53 PM   #6
Chuckinca's Avatar
Why is is bad if the tongue weight is less that 10%?
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 09-12-2012, 09:54 PM   #7
You do have a lot of storage space up front and under the bed (assuming you have the 301blds) so I'm assuming you have a lot of gear stored there already. Are your propane tanks and batteries up on the tongue? If you only have one battery, you could add another - that's 75#.
If all else fails, you could put cases of beer in the front compartment
Before you start carrying around a lot of unnecessary things, I'd go out for that test tow and see how it does as is. But I'm betting you'll want 300# more in the front.
Old 09-12-2012, 09:55 PM   #8
TURBS's Avatar
Hold on cause you'll go for a ride !
Excessive trailer sway will be the end result !
Turbs
Old 09-12-2012, 10:01 PM   #9
Do you have the platform on the tongue as shown in the pics here:
COACHMEN FREEDOM EXPRESS 301 BLDS TOYHAULER TRAVEL TRAILER 2013 at 2012 $ in RVs & Campers | eBay Motors
Looks like a good place for a generator and fuel tanks
Old 09-12-2012, 10:04 PM   #10
timbo7's Avatar
Have a little more storage room left up front, but cannot think of anything else I need to haul, especially that would make a weight difference. Friend suggested trying to relocate the 100 gal. fresh water tank to front underneath side. don't think I would have room for that.
Timbo7
2007 Tundra Crewmax
