Old 06-01-2018, 07:57 AM   #1
Trailblazer 26TH blue lights
I've had the TH for a year without any issues. Though, recently the blue awning lights and underneath the frame blue lights will not come on anymore. (The blue lights over the ramp still work, which has a separate light switch)
The lights are DC, so is there a fuse box for battery powered things? I'm not sure how to fix the issue. I jump wired the switch so the switch isn't the problem. Has this happened to anyone else?
rockinreel is offline   Reply With Quote
Old 06-02-2018, 07:47 AM   #2
SeaDog's Avatar
DC lights fail all the time and a good portion of that time it a ground. Make sure the grounds are tight and that you actually have power to the switch. If there was no power jumping the switch would make no difference.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
light, trailblazer
