Old 04-05-2019, 10:05 AM   #1
Trailer Swaying
Hello Fellow RVers,
I have an issue and looking for some help. I have a 2019 Catalina Trail Blazer 29THS Toy Hauler. I pull it with a 2019 Dodge Ram 1500 5.7 Hemi 4x4. We've had this TT for almost 2 months and taken it out 4 times. twice with my HD 2011 Road Glide Ultra, and twice garage was empty. The MC weights about 980 lbs.
We are very happy so far except for trailer swaying. I am white knuckling on all highways. I have followed many U-Tubes on setting up my hitch. I have the difference from empty to full load to 1/4 inch. The hitch is rated at 14,000 and tongue weight to 1,400. I don't drive over 65 and mainly stay at 60.
What can I do to reduce the sway.
retcsm is offline   Reply With Quote
Old 04-05-2019, 10:07 AM   #2
fonzie's Avatar
What is your hitch manufacturer and model. It will help members give you feedback. Also if you can post your truck yellow sticker capacity, it will help. see example
Name:	Ford door jam stickers.jpg
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-05-2019, 10:17 AM   #3
Does it sway when it is empty? or if the bike is in the back? or both? That will help answer the question. I used to tow a 27HFS with a streetglide in the back with a silverado 1500, it towed better with the bike in it. What a nightmare either way.
wildcatter is offline   Reply With Quote
Old 04-05-2019, 10:29 AM   #4
Zoom's Avatar
My fresh water tank is in the front half and I usually load approximately 25 gallon to get more tongue weight. That may help but I ended up trading my 2014 RAM 1500 (tow package with 392 gears) for a 2016 F250 diesel. The RAM had plenty of power (5.7) but just wasn't heavy enough for my total camper weight of 10,000 lbs. Made a world of difference. My Ram had only 1390 pounds of payload and I was over weight on both payload and GCWR. I white knuckled the first short trip and traded the RAM. Also the "P" rated tires will allow more sway. BTW I haul two motorcycles with a total weight of 1400 lbs.
2015 XLR 29HFS Toy Hauler
2016 Ford F250 Lariat Crew Cab FX4 Power Stroke
2007 Harley Softail Deluxe
2005 Victory Vegas
Zoom is online now   Reply With Quote
Old 04-05-2019, 10:31 AM   #5
Weigh your trailer and measure tongue weight with and without the MC. Without those 2 numbers, everything is a guess at this point.
I would invest in a Sherline scale.
https://smile.amazon.com/Sherline-LM...s%2C203&sr=8-3
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 04-05-2019, 10:35 AM   #6
Toy haulers are typically tail-heavy, which negatively impacts sway. Might want to try putting some water in your FW tank to add some weight to the tongue. Make sure your FW tank is adequately attached first - see this thread for issues.
Traveling with full tanks?
Also see this video:
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 04-05-2019, 10:38 AM   #7
CentralMePistol's Avatar
More information on your hitch would help us- help you....
Does your hitch have sway control? What is the make and model of hitch? Have you done any "improvements" to your truck? What kind of tires are you running?
These are the quick questions I have to help diagnose a possible cause. Also, I am going to assume your trailer is level front to back while hauling.
2018 Cherokee 274DBH
2012 GMC Sierra 1500
4x4, Crew Cab, 5.3 KDL HD Cooling, 3.42 ratio
Recurve R6 WDH w/Sway Control & SumoSprings
Days Camped:2019-18 and counting / 2018-30
CentralMePistol is offline   Reply With Quote
Old 04-05-2019, 10:41 AM   #8
Denver To Yuma In 90 Days
Another 'Not enough truck for the load' topic threads...
JohnD10 is offline   Reply With Quote
Old 04-05-2019, 10:46 AM   #9
Bigger truck, I don't care what the dealer tells you, these big toy haulers shouldn't be pulled by a 1500. 1,200 lbs of tongue weight and your payload is around 1,900, doesn't leave a whole lot of room for you, other passengers, fuel, etc.....
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 04-05-2019, 10:48 AM   #10
Fulltime family RVer
Agreed. Weigh the setup.
Here's how:
Towing Pin/Tongue Weight Calculator | Learn To RV
Plug the numbers into this once you have them:
Actual Weights - Travel Trailer/Bumper Pull Weights from CAT Scales - Towing Planner
ependydad is online now   Reply With Quote
sway, trailer
