Old 05-29-2015, 02:54 PM   #31
TURBS's Avatar
Originally Posted by vinmaker View Post
Not to hijack the thread but a quick question.
Is it possible to check the bearings and NOT replace the seals? Is one able to open up the wheels and check grease and bearings without having to replace the seals?
Just curious.
Thanks,
Vin.
Rear or inner bearing cannot be "inspected nor packed" without removing seal.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 05-29-2015, 03:05 PM   #32
indybp57's Avatar
My Dad always said if you're going to error, its better to be a little loose than too tight, as the bearings can seize if they're too tight and get hot. Been following that advice for 45 years with no problems. Always just grabbed the top of the tire and jiggled it real hard. If I feel just the slightest amount of slack I'm good, never used a dial gauge.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 05-29-2015, 03:12 PM   #33
Good advice, basically what I use as you cannot measure the cup to cone clearance once they are assembled. You can measure the clearance between the washer and the cone, but it is a tedious procedure and not really necessary.
Old 05-29-2015, 06:23 PM   #34
Crockett's Avatar
and I just figured out why timken reduced their spec over the years. Or at least speculated an answer...long fiber grease was the norm back in the day. so its settled...or at least fairly settled compared to most threads...
Crockett is offline   Reply With Quote
Old 06-03-2015, 09:28 PM   #35
Coachmen Chris's Avatar
Exactly how I did it today, Thanks
Do Tell. Never heard of long fiber grease.
So I tightened up the castle nut. I turned it a good 1/4 turn. The play that I felt before I tightened it felt like 1/8 or more.
I hand tightened the nut and there is 1/16 now or less. There is some play but a big difference from earlier. I definitely feel more at ease and comfortable taking it on a trip.
Does anyone know the size grease zerk that goes into that axle or is it standard ?
Coachmen Chris is offline   Reply With Quote
Old 06-03-2015, 11:13 PM   #36
Crockett's Avatar
im in agreement that ANY play you can feel is enough. my question is by grabbing a large rubber object and wiggling it, at which amount of true distance can you discern that there is play there? I dont think your going to feel less than a 1/32" and say there is definitely play there. it be fun in a perfect world to break out a dial indicator and see what the distances feel like. i know i wont torq and then back off a certain rotation. ill torq and then back off and finger tight and back again to the first castelation. ill run that which i assumed felt like an average of 1/8". never measured. never ran for a different thrust washer because it felt too loose. i know when i posted earlier about real loose ..it was in the 1/4" range. at 14 threads per inch your not going to get too precise though the tang washers give more adjustment than a straight cottar key.
Old 06-04-2015, 03:26 AM   #37
Just a member
kandl's Avatar
"Long fiber grease" refers to a grease's tendency to produce long, fibrous strands when extruded or placed under pressure. A misnomer of sorts because there are is no fibrous material in the grease. There are short fiber greases too.
I think you nailed it as regards your bearing's preload. A wee wiggle at the OD of the tire is ok, no movement is a recipe for chewed up bearings.
The grease fitting should accept a standard Zerk with a 1/4-20 tapered thread.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 06-04-2015, 05:17 AM   #38
Zerk Fitting thread size on (Alco/Dexter) Axles can be (1/4-28 SAE or 1/8-27 NPT) Youroo!!
Old 06-04-2015, 05:40 AM   #39
indybp57's Avatar
Originally Posted by kandl View Post
A wee wiggle at the OD of the tire is ok, no movement is a recipe for chewed up bearing.
I was looking for the term "wee wiggle" in the owners manual and couldn't find it. Is that a technical term? :sly:
2013 Roo 183
Old 06-04-2015, 05:47 AM   #40
If (wee wiggle) is too much try (a Tad)! Youroo!!
bearings, wheel
