Old 04-26-2015, 10:17 PM   #1
Coachmen Chris's Avatar
Wheel Bearings
This evening I thought I'd check out one of the sets of wheel bearings. Since I've Completed the inside work I thought I'd tackle the wheel bearings.
I've never done wheel bearings before and to be honest it wasn't all that bad taking it apart.
I looked at the grease and it looked like there was a small amount of red looking grease in with this dark colored grease that looked old.
I was looking to see if I could find and numbers on the bearings and seal and could not find any.
The races looked fine and there were no wear marks , scratches or anything that looked out of the ordinary.
I'm not sure how well maintained these wheel bearings were but I'm leaning towards all new ones.
Here are some pics
Coachmen Chris is offline   Reply With Quote
Old 04-26-2015, 10:19 PM   #2
here are more pics
Old 04-26-2015, 10:23 PM   #3
Can anyone tell me what the threads are for inside the axle ?
What is this notch for ?
Old 04-26-2015, 10:34 PM   #4
Just a member
kandl's Avatar
The threads accept a grease fitting (zerk). The notch is where the grease comes out. This is an Ultrulube setup.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge Ram 3500
kandl is offline   Reply With Quote
Old 04-26-2015, 10:34 PM   #5
northstar1960's Avatar
the bearings look wore ,how do they feel ? loose ? I assumed you wiped off all the grease before you took the pictures. the seal looks damaged lol ,the threads inside look to be for a zerk fitting
northstar1960 is offline   Reply With Quote
Old 04-27-2015, 12:21 AM   #6
Good to know I can add a grease zerk. Will make it easier to grease it in the future.
Yes the wheel bearings felt loose and sloppy. When I pushed/pulled on the tire prior to removal I felt some play in it. Yes I wiped the bearings off before the pics and seal was being a little stubborn lol
Old 04-27-2015, 09:41 PM   #7
Picking up wheel bearings , seals and races tomorrow afternoon. Does anyone put anything on the outside of the seal or run it in dry? TIA for the replies
Old 04-27-2015, 09:54 PM   #8
putting a little grease around it will help it go in easier , knocking out the races can be a real pain some times ,be careful not to damage the hub.
Old 04-27-2015, 10:12 PM   #9
Brother Les's Avatar
With the tire and hub off Look over your brake assembly over very carefully and learn how to tighten and Loosen the brake manually now and it will be a lot easier to do when you do put the hub and tire back on. With the hub and tire on and still up in the air, plug in your truck in to the camper. Spin the tire, does it spin easy or is there any grinding from a tight brake? If it spins easy, have a helper put their foot on the brake, spin the tire, how does the brakes feel?
Brother Les
Old 04-28-2015, 12:31 AM   #10
Just a member
kandl's Avatar
Strongly recommend you pick up a decent bearing/seal driver. They're not pricey and will pay dividends in the grief they prevent. The seals for 3.5K and 4K axles are typically a tight fit and if you don't get it right on the first whack, you'll be off to buy more seals.
bearings, wheel
