Old 05-28-2016, 11:27 PM   #1
Freezer/Fridge AC/Propane
Night before our maiden voyage. Hooked up to shore power at home to load it up. Turned Fridge on and turned on auto to use shore power. Freezer is getting cold, however fridge is not cooling at all. We switched to propane and still freezer is cold and fridge is nada. This went on for an hour. What's with it being auto temp with a sticker that says colder and warmer, what is the white plastic thing attached to the silver cooling coils? Click image for larger version
Name:	ImageUploadedByForest River Forums1464496047.704970.jpg
The Dansers
'16 Nissan NV 3500
'17 Forest River 3250BH
dansers6 is offline   Reply With Quote
Old 05-28-2016, 11:47 PM   #2
bikendan's Avatar
Fridge always takes longer to cool than the freezer, unless something is wrong.
Since it uses absorption cooling, it takes longer to remove the heat from the larger fridge box.
How long have you been letting it cool?
Most of us let it cool for 8 hours before worrying about something being wrong.
Equalizer WDH
Old 05-29-2016, 08:03 AM   #3
Head Rambler
If the freezer is getting cold, the fridge will get cold, but as Dan said, it takes it a lot longer.
The white plastic clip holds the thermister and you can adjust how cold the fridge gets by sliding the clip up for colder, or down for warmer. There should be a pair of wires coming from behind it.
We leave the fridge on all the time that way it's always ready to go.
Gotta go campin!
Old 05-29-2016, 08:30 AM   #4
Depending upon the outside temperature our fridge can take overnight to cool completely and stabilize. Also since it is so small that cool air leaves the cabinet pretty quickly when the door is opened. I added a thermometer so I could see what the actual temperature is.
keith_h is offline   Reply With Quote
Old 05-29-2016, 08:42 AM   #5
Mr. Dan's Avatar
"Auto" doesn't mean 'auto temp' It means auto selection of power source. The thermistor (not just the plastic clip that holds it) must be moved up to make the unit cooler. My single wire wasn't long enough for that so I had to pull a little slack from outside the unit.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 05-29-2016, 10:03 AM   #6
DaveSchwartz's Avatar
Like this?
Name:	RV fridge thermometer.jpg
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-29-2016, 10:29 AM   #7
Originally Posted by DaveSchwartz View Post
Like this?
Not like that. Just one of those alcohol bulb types I hang from the shelf. It is accurate within a degree or so which is close enough when our fridge settles in around 34-37 degrees Fahrenheit depending upon the outside temps.
Old 06-10-2016, 07:26 PM   #8
Originally Posted by dansers6 View Post
Night before our maiden voyage. Hooked up to shore power at home to load it up. Turned Fridge on and turned on auto to use shore power. Freezer is getting cold, however fridge is not cooling at all. We switched to propane and still freezer is cold and fridge is nada. This went on for an hour. What's with it being auto temp with a sticker that says colder and warmer, what is the white plastic thing attached to the silver cooling coils? Attachment 109426
The Dansers
'16 Nissan NV 3500
What's the outside temperature where you're parked? I just got back from camping in the Anza-Borrego Desert where it was 118 F outside and the fridge warmed up to 58 in the middle of the day. I have since modified the vent stack of my fridge by installing a couple of 120mm computer fans. I'm waiting for another hot day to test it out.
Kevin
kevink619 is offline   Reply With Quote
Old 06-10-2016, 07:31 PM   #9
Oaklevel's Avatar
X 10 ........ the frig usually takes a while...... several hours to cool down.......
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 06-10-2016, 07:50 PM   #10
bob dirt's Avatar
I start mine several days ahead of time and when it's really hot out I'll put a bag of ice in the freezer compartment to help it out AND run the A/C
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
fridge, propane
