Old 12-08-2015, 05:00 PM   #1
Evo2700's Avatar
Lippert Electric Jacks
My rear electric jacks are stuck in the up position. When I try to put them down I can hear the motor run, but the jacks don't move? Easy fix or do I need to replace the jacks?
2015 Evo 2700
2017 Ram 2500 6.4 Hemi 4.10
Evo2700 is online now   Reply With Quote
Old 12-08-2015, 05:32 PM   #2
Fulltime family RVer
They might just be stuck. It happened a few times on mine. The motor would try to start and then would pop an automatically resetting fuse and everything would stop.
I ultimately had to use the manual crank and force it to turn. Once I got past the first inch or two, the motor could do its thing. Once it was down, I lubed the hell out of the "worm screw" or whatever that cross-bar is called. Ran it up and down and sprayed dry lube on it liberally.
Old 12-08-2015, 05:46 PM   #3
Evo2700's Avatar
Thanks!!!! That worked. Problem solved.
2015 Evo 2700
electric, jacks
