Old 01-17-2015, 06:00 PM   #1
Evo2700's Avatar
Mounting a TV
Is there a certain mount I need to mount a TV in my Evo? The spot designed for the mount seems like that cheap cardboard wood and I'm worried that over time it won't hold up. Also, directly behind the cubby for the TV in the living room is a cubby to mount a TV in the bedroom...will a TV on both sides of the wall hold up? The first picture is the living room side and the second is the bedroom side.
ID:	68515   Click image for larger version
2015 Evo 2700
2017 Ram 2500 6.4 Hemi 4.10
Evo2700 is offline   Reply With Quote
Old 01-17-2015, 06:04 PM   #2
dcheatwood's Avatar
Hopefully someone with a unit like yours will chime in but, if there is a spot designated for TV wall mount, there should be extra support in the wall at that point.
2018 Forester 3011 DS
Old 01-17-2015, 06:17 PM   #3
Evo2700's Avatar
I'm sure it will hold at least one TV, but I question it being able to hold a TV on both sides of the wall.
2015 Evo 2700
Old 01-26-2015, 10:43 PM   #4
HONDAMAN174's Avatar
I guess it just depends how big you want to go. We went with a swing arm mount with a 24" led for weight and lower power usage as I have it wired into an invertor. Was thinking of putting a TV on the backside but was thinking of the volume wars between us and the kids- not to mention haven't had the need for it yet.
I think it should be able to hold a 32" fine on one side- bolts seemed pretty secure on my when installing.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
mount
