Old 01-28-2013, 05:29 PM   #11
Hi Herks, I live in Perth Western Australian and when the trailer arrived there was no manual. The slide out has zigzag (not a technical word but the best I can do to explain) aluminum runners top and bottom on both sides of the slide out. I can hear motors turning over but I haven't been able to see them and I am wary of pull things apart at present. If I supply photo could you help?
Cheers for the prompt reply which I appreciate.
Frances Richards is offline   Reply With Quote
Old 01-28-2013, 05:54 PM   #12
Herk7769's Avatar
I (and every one here) will do our very best.
Did you happen to see a crank handle anywhere in the camper?
Do you have a hole in the side opposite the slide in question?
Name:	9 Nov 2009 003.jpg
HAM CALLSIGN - KC3FFW
Old 01-28-2013, 06:10 PM   #13
Sounds like you may have a Schwintek In-Wall Slide which is a little more complicated when it does not work correctly. Here is a link to a video describing how to disengage the motors and move the slide manually. Lippert also has on-line manuals for these slides that can be downloaded and printed for reference.
Sirsea is offline   Reply With Quote
Old 01-28-2013, 06:11 PM   #14
Hi Lou,
No crank but I have think I may have cracked the problem as to who provides the slider mechanism. The system is not hydraulic which would make my live easier but driven with electric motors. I am hoping its a Schwintek and I am trying to identify the mechanism. They have put together some videos on UTube which help a lot, so if they are the manufacturer I can put this issue to bed.
Again thanks..
Old 01-28-2013, 06:17 PM   #15
Herk7769's Avatar
Sounds like you have a handle on it.
Thank you Sirsea for the video and the Lippert tip.
This is an install video and might help you visualize the mechanism.
Old 01-28-2013, 06:18 PM   #16
I am very impressed with the prompt replies and assistance I have gotten from this forum. As a member of just one hour.. Can't thank everyone enough especially with the time difference.
Old 01-28-2013, 06:19 PM   #17
Herk7769's Avatar
Lippert manuals can be downloaded form here:
Lippert Components, Inc.
Old 03-19-2014, 05:34 PM   #18
new to forum. Our problem (besides the broken frame) is the slides and the front jacks both run when you try to open/close slides or raise/lower jacks. Any others experiencing this freakish problem? Any suggestions for solving?
SusieBlueBonet & Tugboat2H
'06 Wildcat 29RLBS
'08 Chevy Duramax
SusieBlueBonet is offline   Reply With Quote
Old 03-19-2014, 07:50 PM   #19
I have not had any problems with our slide out and I have collected an number of video's which Lippert have on their web site which cover most issues.
Lippert Components Media DAM : Folder - Videos
Old 03-19-2014, 07:56 PM   #20
Slide out problems
Any suggestions how to check slide out switch on our 2007 5er 8285. When press no sound at all. Checked breaker,fuse,battery??
beachhrlygrl is offline   Reply With Quote
hydraulic, slide out
