Old 01-04-2016, 08:28 PM   #1
Switch next to the fuse box
Hi,
We just recently bought a 2014 EVO 3250 (slightly used) and went through a thorough inspection before taking it home. Everything is fine but the salesman couldn't tell us what the switch next to the fuse box was for. It looks like any of the other wall mounted light switches on the walls but is low on the floor next to the fuse box. Our EVO had the Climate "B" package which I am assuming is the Arctic Package. Could the switch go to heat tape under the TT? Any info on this would be appreciated.
Thank You
J & T
JVM
2014 EVO T3250
2002 GMC Yukon 2500XL SLT 4x4, 6.0, 4:10
Husky Centerline WDH w/sway
BukerRV is offline   Reply With Quote
Old 01-04-2016, 09:07 PM   #2
HONDAMAN174's Avatar
Picture would be great
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 01-04-2016, 09:51 PM   #3
I am working a 24 today but will try to post a pic tomorrow.
John & Theresa
JVM
2014 EVO T3250
Old 01-05-2016, 08:17 PM   #4
Here is a picture of the switch next to the fuse/circuit breaker box. It is just a regular white light switch. I don't know what it controls and why it is in that location. Any ideas???
Thanks for any help
John & Theresa
JVM
2014 EVO T3250
Old 01-05-2016, 08:25 PM   #5
Switch Picture
Sorry about that. The picture is attached.
Thank You
John & Theresa
JVM
2014 EVO T3250
Old 01-06-2016, 12:55 PM   #6
StlClay
Your switch
On my unit (not the same model) this would be the battery shut off switch. Maybe you can check that out. Just turn sme lights on without being hooked up to shore power. If the light go out when you try that switch, should be a pretty good sign. Good Luck
2014 MiniLite with
Nissan Frontier
Stlcaly is offline   Reply With Quote
Old 01-06-2016, 02:17 PM   #7
Stlcaly,
I tried it and it is not the battery shutoff switch. I did notice that when I turn on the switch that the lights dim a little so it must be used to power something.
The search continues....
John & Theresa
JVM
2014 EVO T3250
Old 01-06-2016, 02:19 PM   #8
Our Sanibel 5r has a similar switch by the door. It turns on a light above the door so you don't walk in to a dark camper. It is low and beside the fuse panel.
James Briar is offline   Reply With Quote
Old 01-06-2016, 02:33 PM   #9
James,
Ours have a switch for the light next to the door also but it is located right next to the entry door. The unknown switch and our fuse/circuit panel are located in the middle of the trailer just below the wardrobe closet.
I submitted a question to the Forest River Service department but have not gotten a reply back yet.
Thank You
John & Theresa
JVM
2014 EVO T3250
Old 01-06-2016, 02:44 PM   #10
Electric to the water heater?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
fuse
