Old 03-21-2017, 11:58 PM   #1
TV/stereo problem
Spent last weekend running every system and appliance in my 2016 Evo 220RBS to make sure they functioned properly on all applicable types of power. The only issues I found were with the stereo system. The first issue was the right interior speaker did not work. Found a loose connection where it plugs into qthe back of the unit and it works fine now. The issue I have yet to resolve is that I have no audio from the Jensen TV through the stereo. The cables go from audio out on the TV to audio in on the stereo, but no matter which audio source I select the sound does not come through. Any ideas?
Evo220rbs is offline   Reply With Quote
Old 03-22-2017, 06:34 PM   #2
It's possible the Jacks don't work. Do you have an optical cable output from the TV into the stereo?
Mdaniels4 is offline   Reply With Quote
Old 03-22-2017, 07:39 PM   #3
The Tv does, not the stereo. Might have to remove tv from trailer to try and plug it in to something else to make sure output jacks are working
