Old 12-11-2017, 07:10 PM   #1
mhbell's Avatar
Send a message via Skype™ to mhbell
Water Pump Location
Where is the water pump located in a 2017 EVO T2360. I haven't found it yet. I don't want to de-winterize it to listen for the pump.
Mel
2017 Forest River EVO T2360 Towed with a 2011 F-250 Super Cab Super Duty 4WD Tow Pkg Blue OX Sway Pro Hitch www.rvbloggers.wordpress.com
mhbell is offline   Reply With Quote
Old 12-12-2017, 04:22 PM   #2
mhbell's Avatar
Problem solved
After turning on the pump and listening, I could hear the pump running under the kitchen sink cabinet. The sound was coming from the bottom of the kitchen sink cabinet. I had to remove the bottom drawer in the kitchen sink cabinet to get to it. There is a cut out under the drawer, so I will cut it out and make a access panel so I can get to the pump to remove the filter also to add a T hose and cap to the inlet for pumping RV Antifreeze into the lines when winterizing. That way I would not have to pour 3 or 4 gallons into the tank so that the pump could suck up enough antifreeze to winterize the pump and filter bowl.
Mel
Old 12-12-2017, 04:31 PM   #3
Mr. Dan's Avatar
You said "so I will cut it out". You didn't find a nearby panel attached with screws. When I've looked for water pumps for myself and others, I've always found a screwed-on panel to access the water pump. Some installations were very crude! but still they were screwed into place.
We're happy you found your pump anyway!
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 12-12-2017, 07:51 PM   #4
mhbell's Avatar
no panel with screws
There was no panel with screws. I had to remove the bottom drawer on the kitchen sink cabinet to get to the pump. There is a blank panel below the drawer that I can cut out and put a piece of panel in it place with screws for easy access.
Mel
cat, location, pump, water, water pump
