Old 04-18-2017, 04:11 PM   #1
Newbie Trailer Camper!
Where is the water heater bypass valve?
I just bought a 2014 Forest River Evo T2850. I'm new to camping and trying to dewinterize to get ready for our first trip this weekend. It wasn't winterized with antifreeze, previous owner just aired the lines out. I want to sanitize the fresh water system and found steps to do it, but can't find the water heater bypass valve. I found the anode rod outside which was removed for the winter. Also found a small hot and cold water low point drains outside, and a big fresh water low point drain valve. But can't find the water heater bypass. I can't see a way to access the water heater from inside. It appears to be under the stove.
onecrazyfoo4u is offline   Reply With Quote
Old 04-18-2017, 04:24 PM   #2
Ford Idaho's Avatar
Are there a couple of screws holding on a panel?
If so remove the screws an see if the valves are there.
Is the fridge next to the stove?
Panel under it?
Old 04-18-2017, 04:24 PM   #3
fonzie's Avatar
If panels underneath stove can not be removed, then remove the two drawers next to stove and see if you can access valves.....
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-18-2017, 04:28 PM   #4
Looking at one online, it looks like it's below your stove. However, it doesn't look like there's direct access from there. You may have to open/remove the drawer(s) under the sink and get to it from the side.
The other access route may be to remove the furnace's return air return under the fridge and get to it from the other side. (You're furnace is under your fridge, BTW.)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 04-18-2017, 04:31 PM   #5
Yeah it does have screws in the panel under the stove. I'll try taking that off tonight to see if I can get to it. The fridge is just to the right of the stove, so no access there.
Old 04-18-2017, 04:35 PM   #6
Ford Idaho's Avatar
Suggested approach, belly crawl, with lots of lumens and long arms will be a big bonus.
Old 04-18-2017, 11:11 PM   #7
So I was able to get to it through the acess panel under the stove. Thanks for the help there!
Attached a pic to show the 3 valves, one hot, one cold, and one in between. Which valves do I open when doing dewinterizing and cleaning the fresh water system? And after its all cleaned out, which valves do I leave open to use the hot water heater all summer? Thanks again!
Old 04-18-2017, 11:15 PM   #8
Broadway Joe's Avatar
it's perfect as shown. The cold supply is open, hot is open middle bypass is closed.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 04-18-2017, 11:42 PM   #9
I thought to clean out the fresh tank, lines, and water heater you had to close some valves though? When would you ever open the middle bypass?
Old 04-18-2017, 11:50 PM   #10
bikendan's Avatar
when you winterize.
you open the middle and close the other two, to bypass the WH.
Equalizer WDH
bypass, heater, valve, water, water heater
