Old 04-23-2019, 10:25 PM   #1
18 38C questions
2018 legacy 38C I have some questions
Which battery’s are the house and which are the chassis,? One set has 2 12V and one set has 4 6 or 8 volts???? Thanks for your help
Headlights are about 2-5foot low from where I would like them. On the model hoe do you adjust them????? Thanks
16' Cherokee wolf pack 20pack10
Rzr 1000
Outlander 1000
•All pulled by 15' Gmc 2500HD duramax
Ozziedodge67 is offline   Reply With Quote
Old 04-23-2019, 10:42 PM   #2
cavie's Avatar
2-12 volt Chassis.
4 - 6 volt house.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 04-23-2019, 10:45 PM   #3
Originally Posted by cavie View Post
2-12 volt Chassis.
4 - 6 volt house.
Any headlight thoughts
Rzr 1000
Outlander 1000
Old 04-23-2019, 10:48 PM   #4
Thanks for that info
Generator starts off of the chassis (2X 12V) battery’s correct?????
Rzr 1000
Outlander 1000
Old 04-24-2019, 07:44 AM   #5
Lacey's Spring, AL
formerFR's Avatar
nope, House batteries...
only the engine and a few other 12v items tied to the ignition, like the entry step, run off the Chassis batteries
as for the lights, there's little to no adjustment - why do you feel the need?
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 04-24-2019, 07:45 AM   #6
Lacey's Spring, AL
formerFR's Avatar
you can also update your Signature, otherwise you may be confusing a lot of folks who jump into these forums from the right hand column, not understanding that you are now talking about a Legacy diesel pusher...
Old 05-16-2019, 03:03 PM   #7
Headlights
We had similar issue with our '18 Legacy 38C with the headlights pointed what felt like straight down. Took it to local Freightliner and they adjusted them for free. Now we can actually see what is in front of us while driving.
NickC is offline   Reply With Quote
Old 05-16-2019, 09:43 PM   #8
I have a 15 legacy, there is an adjustment for up and down on the headlight. It’s a plastic screw on the back of the headlight assembly that takes an Allen wrench. You can get to it through the generator compartment or by coming up underneath. If you can park it about 20 feet from a wall, turn on the lights and mark where they are hitting with masking tape. You can then adjust them up a little if necessary. I never got mine to work very well. When I adjusted the low beam to hit 50-75 feet In Front of the coach, the high beams were lighting the tree tops. Turning on the fog lights for all night driving helps.
tmartin is offline   Reply With Quote
