Old 03-25-2017, 02:39 PM   #1
340BH Kitchen Sink Leak
So I've noticed a few times now that I get major leaks from under the kitchen sink.
It seems to be a slow leak from where the hard lines hook up to the flex line.
Basically the pipe goes down, then hooks to the flex line - then loops UP so it's a natural trap. Water just sits there on the connection from hard line to the flex hose and leaks leaks leaks.
It's ruined part of our lower cabinets as we had it parked for winter and a ton of water/rv antifreeze leaked out all.
Has anyone had this problem? We've removed and re-connected the two multiple times but it always leaks again.
I talked to the dealer I purchased it from but they could really give a crap. It's been a little over a year so I guess that explains it.
Included picture attached for location where it's leaking. Anyone else having this problem? How did you fix it?
I was thinking about replacing part of the flex hose with a rubber hose or something then re-linking to the flex hose below?
2015 Forest River Legacy + 2014 Jeep Grand Cherokee TOAD
doofoo is online now   Reply With Quote
Old 03-25-2017, 04:30 PM   #2
aeroshots's Avatar
Just a thought. How about pvc primer then pvc cement then clamp. If you are going to replace that part of the flex hose anyway, why not.
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 03-25-2017, 04:36 PM   #3
At this point I'll try anything. It's just annoying the design because even if I get it not to leak, it will still be a natural trap that stagnant water just sits in.
I found another old thread where people were talking about the flex hose kinking, it's just crazy all the crap design on these rigs.
Old 03-25-2017, 06:32 PM   #4
I purchased and installed a 90 degree angle fitting, cut the flex hose and installed it right where the flex hose was going into the floor. It solved the kinking problem and the flex hose is now laying flat on the floor, not holding any water in it.
tmartin is offline   Reply With Quote
Old 03-26-2017, 05:46 PM   #5
A32Deuce's Avatar
Is that a sink in a slideout?
A32Deuce is offline   Reply With Quote
Old 03-26-2017, 05:48 PM   #6
It is.. I understand the reason for the flex line is because it moves a bit, but it's just crazy that they use a hose clamp on a flex line the way they did. It just doesn't seal well at all.
Old 04-02-2017, 02:49 PM   #7
I never noticed, but there is a drain pipe that comes out of the back and wraps back around towards the cooktop/bunk beds.
Anyone have any idea where this drain comes from? It looks like it hooks in right before the flex line.
** This is all UP TOP in behind the cabinets, not the hard line that is down below **
Old 04-02-2017, 02:52 PM   #8
Your's looks a bit different than mine, but here's an issue I had; maybe it will help you:
Mini Lite 2503S kitchen drain broke
2011 Traverse LT, 3.6L, FWD
Old 04-02-2017, 03:07 PM   #9
Pictures attached.
First pic is the pipe I'm talking about.
Second is a picture of the pipe going back behind where the bunks are (this picture is from after I removed the drawers from the kitchen.)
Does this drain both ways? Through the flex line and through this hard line perhaps?
Old 04-02-2017, 03:08 PM   #10
ID:	133634Click image for larger version
leak, sink
