My driver side wiper blade is not making contact with glass on bottom edge at full sweep, blade vertical. Leaves a streak of water along bottom radius. Blade is lifting off glass slightly. Blades are less than 6 months old, any ideas?
Arms are tight and adjusted and park/sweep evenly.
My wipers never really make full contact with the windshield. I tighten the springs and now all is good. I took the wipers off removed the spring then slide the spring retaining hook up.
My wipers never really made full contact with the windshield. I tighten the springs and now all is good. I took the wipers off removed the spring then slide the spring retaining bracket up.
I’ll check check the spring. Passenger side works as expected. Drivers side starts ok but by the time it reaches point of most travel only half the blade is contacting windshield. Seems odd.
