Old 03-21-2019, 12:26 AM   #1
Air Compressor Line
Has anyone found a place to effectively mount an retractable air line reel from the compressor fitting? I guess you could run a line from the front to the DEF tank compartment! Any ideas?
necasperaterrent is offline   Reply With Quote
Old 03-21-2019, 06:48 AM   #2
Lacey's Spring, AL
formerFR's Avatar
are you referring to an AIR HOSE, attached to the front air connector, for use of keeping tire PSI levels, etc.?
For several years I simply wound my 50' orange air hose around the front chassis rail that ends within the generator area - never a problem. You could 'try' to find a small reel that you could also mount there, but it seems a little overkill for the few times you use the air hose, and the mounting would take some work.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
