Old 02-25-2017, 04:18 PM   #1
air hose and chuck
Sorry if this is a silly question ... is this the hook up that I can use to attach a hose and chuck for filling my tires? What is the process? Does the coach need to be on?
Thanks for the help!
Legacy Owner is offline   Reply With Quote
Old 02-25-2017, 05:14 PM   #2
Ford Idaho's Avatar
Yes it is and yes the engine needs to be running in order for the compressor to build air.
You might look at something like this.
https://www.googleadservices.com/pag...uxcIygE&adurl=
And this.
https://www.googleadservices.com/pag...QvhcIQw&adurl=
Old 02-25-2017, 05:50 PM   #3
Great, thank you!
Old 02-25-2017, 05:51 PM   #4
Do you use a hose on a reel? If so, where did you mount it?
Old 02-25-2017, 06:38 PM   #5
Ford Idaho's Avatar
No I do not, not much need of air tools anymore so I just have a small pancake.
Old 02-26-2017, 01:41 PM   #6
padcarroll
I use a good high quality hose from Lowes with standard quick connects. The only problem I have is the max air pressure on the air tanks is 100 psi and the tire pressure is supposed to be 105 psi. I can about 2 more psi when the compressor is actually running.
Dave and Pam Carroll
Callie - 9 yo chihuahua/yorky mix
2014 Legacy SR300 340BH
2013 Chevy Sonic Toad
Full-timing since January 2016
padcarroll is offline   Reply With Quote
Old 02-26-2017, 06:38 PM   #7
Fulltime family RVer
I had a 3 gallon Porter Cable pancake air compressor and could only go up to 108 psi. My new tires were 125psi, so I ended up selling that compressor and opted for a Viair 450P.
More info and full review of it here:
http://learntorv.com/product-review-...ir-compressor/
Old 02-27-2017, 12:48 AM   #8
captnrick3's Avatar
Good replies. I use a small diameter air hose from Lowes or Home Depot and a standard tire air chuck. If you are not familiar with these fittings be AWARE when disconnecting. Be sure to hold the hose securely with one hand, and the sleeve on the female fitting with the other. Serious injury could occur as the hose blows out if not.
The only time there is enough air to fully inflate tires is just at the moment the compressor cycles off. ( you can here it operating when the engine is running). If the air pressure falls below 105 or so while airing tires, just expell some air from the hose to cause the compressor to start running again to build up more air. However, if you are in a low tire situation because of a leak, any air is far better than no air. This connection is a great tool to have available.
Not a big deal though, unless there is a leak, your tires will do well at holding their air pressure. I have 25,000 miles and have checked and topped them off many times and have yet to find any more than 5 lbs. off. I use 110 lb. front and 115 lb. rear, just me.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
