Old 01-09-2016, 10:51 PM   #21
captnrick3's Avatar
Originally Posted by Blacknchromehd View Post
well during the winter I have inside storage and 20 amp 115 v I use to keep small items running...building is heated...in the summer I have outside storage with a 50 amp and keep the coach running just like camping...AC and everything...Bad?
Perfect
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 03-20-2016, 03:10 PM   #22
Blacknchromehd's Avatar
Question.....I thought being plugged in during the winter Would keep my chassis batteries fully charged but I was wrong....house are fine...should I install a battery charger that works of the house ones to keep the chassis fully charged?
Blacknchromehd is offline   Reply With Quote
Old 03-20-2016, 11:58 PM   #23
captnrick3's Avatar
There is a small device in the house battery compartment, battery isolation manager, that should be splitting off a small charge to the house batteries. While doing general maintenance on my rig I noticed slower engine cranking than I like to hear even though we had been on the road days before. I disconnected, cleaned, and fully tested the house batteries, they were junk. I have little faith in those OEM Alliance batteries so I replaced them. Would not have been worth my time to take them to Freightliner since the Mfg. date on the batteries was out there a bit. After hooking up the new batteries I connected a shore power line and found that the chassis batteries did in fact receive a trickle charge.
After all that blather, hopefully you don't have a fuse or bad connection preventing your chassis batteries from receiving a charge. I would seriously scrutinize the batteries first.
2015 Legacy 340KP
2012 Wrangler Sport
Old 03-23-2016, 03:17 PM   #24
well I bought another device that I will install which will charge better ...also Freightliner is looking at the batteries for the chassis and if bad will replace them under warranty
Old 03-24-2016, 03:45 PM   #25
captnrick3's Avatar
Good show! Wish the dealers were more convenient here. Winter storage is kinda foreign ground for me, if we get to 30 degrees for a few hours some nights in February we think the ice age is coming.
2015 Legacy 340KP
2012 Wrangler Sport
storage, winter
