Old 05-05-2016, 09:15 AM   #1
ScottPM's Avatar
aux power dash button
2015 legacy 369rb, has anyone noticed the aux power button on dash dimly glows when plugged into shore power? and occasionally it flashes on brightly for a second. I have not noticed it doing that when inverting.
Thanks for any input
Scott Menard
2015 Legacy 360 RB
ScottPM is offline   Reply With Quote
Old 05-05-2016, 10:04 AM   #2
Not sure what you are referring to. If it is the battery boost function you are probably seeing the converter and the battery control center doing its thing.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 05-05-2016, 10:26 AM   #3
ScottPM's Avatar
yes I am referring to the battery boost button on the dashboard. it stays dimly lit when I am plugged in and flashes brightly for a sec on occasion. didnt know if anyone else has noticed it or if maybe I have some wierd issue
Scott Menard
2015 Legacy 360 RB
Old 05-05-2016, 12:45 PM   #4
I suspect that it is just the system voltage as the BCC switches the chassis battery on an off and the converter changes output voltage.
2015 335DS
Old 05-05-2016, 02:16 PM   #5
aeroshots's Avatar
Same with mine. I'm recalling another thread about this. Normal indication as I recall.
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 05-06-2016, 01:41 PM   #6
captnrick3's Avatar
Yup. All normal. I can't find that past thread either, however it's basically a function of the inverter and related attached system working together to keep the chassis batteries charged, etc. I would be concerned if the light quits flashing.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 05-08-2016, 03:04 PM   #7
7 Year Class A RV'er
The other thread is the same OP, just outside the Legacy forum.
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
power
