Old 05-26-2015, 07:06 PM   #11
psw757's Avatar
Regardless of whether your plugged in or not you need to make sure that battery on off knobs in battery bay are on and that your battery disconnect at the inside steps is turned on, red light should be on.
My guess is one or both are off since you had it in storage unplugged.
psw757 is offline   Reply With Quote
Old 05-26-2015, 07:51 PM   #12
rbrtmorris's Avatar
Name:	ImageUploadedByForest River Forums1432687787.165918.jpg
I seem to have 6+ volts per battery when tested individually with meter. And disconnect switch is on. There must be a fuse?!? I'm looking for the battery control centre
rbrtmorris is offline   Reply With Quote
Old 05-26-2015, 07:53 PM   #13
rbrtmorris's Avatar
Battery disconnect switch inside coach by step will not turn on unless I start engine
Old 05-26-2015, 09:22 PM   #14
captnrick3's Avatar
The battery disconnect (intellitec) solenoid is located in your left front bay. There are two solenoids in that bay directly in front of you as you open the door. One connects accessories when you turn on the ignition key, the other is the chassis disconnect solenoid controlled by the toggle switch near the entry door. It sounds to me like that solenoid is not connecting for some reason. There is an inline fuse in the activation line for that solenoid that could be blown, or the terminals could just have come loose. Possible but unlikely the solenoid has failed. I just disconnected the activation wire on the chassis solenoid on my rig to simulate your problem and the symptoms match. Not sure why the problem, but that's where I would focus my attention. Hope that helps.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 05-31-2015, 12:12 PM   #15
rbrtmorris's Avatar
I replaced the fuse as pictured and all power restored to unit 👍. Thanks for all help!!!Click image for larger version
Name:	ImageUploadedByForest River Forums1433092324.454324.jpg
Old 09-01-2016, 04:19 PM   #16
SS Groovette's Avatar
We are having the same issues with our 2014 Legacy. We have looked for the fuse but we have a different configuration. Any advise?
SS Groovette is offline   Reply With Quote
Old 09-06-2016, 10:22 AM   #17
Name:	ImageUploadedByForest River Forums1473175348.659624.jpg
Old 09-06-2016, 10:23 AM   #18
Finally found the bad fuse that was referenced above. It was bad and after swapping it out we are on our way.
battery, charging
