Old 12-19-2014, 08:21 AM   #1
psw757's Avatar
Battery Charging?
Does anyone know for certain whether or not our chassis batteries are trickle charged while plugged in? I haven't gotten a confident answer from the dealer.
Thanks!
psw757 is offline   Reply With Quote
Old 12-19-2014, 06:17 PM   #2
rskrbina's Avatar
Plug your rv into shore power and measure your chassis battery (s) with a voltmeter. If the voltage is anywhere between 13.2 - 14.2, then your chassis battery(s) are being charged while plugged into shore power. Hope this helps.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
rskrbina is offline   Reply With Quote
Old 12-29-2014, 01:48 AM   #3
43D18's Avatar
I would be shocked if they were not being charged while being plugged into shore power. Every motorized RV I've owned (3 so far) have been this way. Report back and let us know what you find though!
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 01-19-2015, 09:17 AM   #4
We had a problem with our batteries charging. To the point the engine wouldn’t start. We put a charge on it got it running. We headed south over Christmas with the thought that if we had an issue with the batteries we would replace them in route. We stopped to see my son and sure enough the house batteries were down and not charging. We shut everything down and the next morning stopped at the camping world in Savana and had them take a look at it. Turns out we had a blown fuse on one of the relays. They replaced it and it seems to be working fine now. We did talk to Mitch at the factory and were told that this appears to be a design flaw that the 2 relays may not handle all the power flowing through them and can blow the fuse. Forest River already has a fix for it and apparently a service release.
Minshall1 is offline   Reply With Quote
Old 01-19-2015, 09:53 AM   #5
bubbles's Avatar
In a FR MH I believe when on shore power the coach batteries have priority and when driving chassis battery has priority but all batteries are charged with either configuration.
Old 03-10-2015, 10:58 PM   #6
captnrick3's Avatar
I will check mine in a few days and see what the scoop is. Since I have had no issues, did not even think of this issue.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 03-25-2015, 10:50 PM   #7
captnrick3's Avatar
Thanks!
Checked mine today and for sure the chassis batteries are receiving a charge on shore power. Stand alone volts 12.3. Shore power plugged in 13.1. All good.
2015 Legacy 340KP
2012 Wrangler Sport
Old 05-26-2015, 07:02 PM   #8
rbrtmorris's Avatar
I've opened my 2015 Legacy after being stored over winter (unplugged). I have power to outlets, fridge, awning, microwave, and televisions while plugged into shore power. (30amps) however I have no power to Lights, slideouts, A/C, ceiling fans, water pump unless engine running. Also I can only start generator while engaging AUX start switch but once released the generator immediately shuts off?!? Can anyone assist me with the issue?
rbrtmorris is offline   Reply With Quote
Old 05-26-2015, 07:26 PM   #9
Batts-toy's Avatar
Either your coach batteries are totally dead (need charging) or your battery disconnect is in the disconnect position and not giving you power from the coach batteries. Your AC runs on 110vac but requires 12 volt from battery for the thermostat and controls this is why it also will not go. Make sure your disconnect is closed and charge your batteries with a stand alone battery charger overnight and try again. If the coach batteries are totally dead they may be runined, you may want to get them tested.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 05-26-2015, 07:30 PM   #10
Herk7769's Avatar
The battery control center has some fuses in it that can prevent the batteries from charging on shore power if blown.
Yes, both chassis and starting batteries should charge when the camper is plugged in AND the battery disconnect is "connected."
Name:	Battery Control Center Schematic FR.jpg
HAM CALLSIGN - KC3FFW
battery, charging
