Old 08-10-2015, 11:42 PM   #1
Battery Corrosion!
Does any one know? is there a pad to place under the batteries or some other way to reduce corrosion from eating the compartment floor?
It sure doesn't appear that the factory has used anything? Should there be a vent?
necasperaterrent is offline   Reply With Quote
Old 08-11-2015, 06:24 AM   #2
TURBS's Avatar
Battery should be in a battery box and vented.
Really can't help much without Year, make and model?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-11-2015, 07:55 AM   #3
Dutchtexan
Dutchtexan's Avatar
Yes there is an item that is exactly what your looking for.BATTERY MAT ACID ABSORBER & NEUTRALIZER you can get them on eBay and other online sites. I use them for batteries that are not in a box but in a compartment and they work great.
Battery Mat Acid Absorber Neutralizer | eBay
TT: 2014 Forest River 27VRL Super-V
V-nose TT w/Rear Living area, 2 slides, Equal-I-zer 4 point hitch #10000
TV: 2011 Chevy Silverado Z71 Extended Cab AirLift 1000 w/WirelessAIR
Dutchtexan is offline   Reply With Quote
Old 08-11-2015, 08:04 AM   #4
extremebike's Avatar
Use baking soda.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 08-11-2015, 08:12 AM   #5
jeff64's Avatar
X2
I'd add not only clean battery top and terminals with baking soda but, the sides too and rinse well. blow dry and buy a battery box. Do this beginning of season. Fill water with distilled water ONLY, to bottom of split rings. If you want to get maximum life out of your deep cycle batteries!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-11-2015, 08:17 AM   #6
KyDan's Avatar
It's a PIA but you need to remove the batteries and scrub the floor with baking soda. Rinse well and dry. Paint with rustoleum. Get battery mat as recommended below and put it all back. With any luck you won't have any
more problems for a long time!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-11-2015, 10:13 AM   #7
2014 Legacy SR300/340 KP battery issues
Thank you for all the info. I can't believe FR didn't put mats in the compartments?
Old 08-11-2015, 10:24 AM   #8
mud yapster's Avatar
I fought battery corrosion on my last truck until I bought a can of battery post cleaner and a can of battery post spray sealant. Clean your cables and battery posts real good then spray the battery post cleaner on them and it will remove any remaining acid residue and then wash it off and dry the posts off. install your cables back on the batteries then spray the battery post sealer on them. I gave my battery posts 3 coats letting it dry in between coats. That solved all my corrosion issue once and for all. I use the battery post sealant now on every battery I have including my RV, cars, Truck, riding mower, atv and tractor battery. Works excellent!!!
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-11-2015, 11:04 AM   #9
DaveSchwartz's Avatar
Puzzled...
If you have ongoing corrosion issues under the battery that means you either have a cracked case (unlikely) or some other charging issue that is boiling acid solution out of the battery. Properly maintained systems do not blow acid out of the cells and simply soaking it up is not a long-term solution.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 08-11-2015, 11:14 AM   #10
Originally Posted by DaveSchwartz View Post
Puzzled...
I don't have a issue but my old t ton truck did cause it was so hot under the hood in this Texas heat and I dought the charging system on my old truck was worth a crap. LOL
battery
