Old 03-08-2017, 12:25 PM   #1
MERJnTravel's Avatar
Black/Gray tank sewer hose access
I'm curious if anyone else has the sewer hose access port offset from the Y connection on the coach?
I was looking at changing to the waste master system with Cam lock connectors, but it doesn't look like I could make it work with the offset opening. I have to use a 45 degree elbow to get it to work with my Rhino hose now.
Just wondering if this is a manufacturing defect on my coach or if the offset is intentional?
Thanks,
Jonathan
MERJnTravel is offline   Reply With Quote
Old 03-08-2017, 12:28 PM   #2
Who Dares, Wins
doc73's Avatar
Well that is a crazy looking setup (not saying its wrong, just wierd). If it is not going to work my guess is you either need to cut the pipe and fix it so it lines up or maybe make your 45 adapter be the start of the waste master system.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 03-08-2017, 12:48 PM   #3
or you could cut a 10" hole instead of the factory 6" hole, like Thor did for ours...
it's NICE to have much more room to move your hose around in, much easier hookup...
don't know why all the factories don't make them 10"
The Turners...
formerFR is offline   Reply With Quote
Old 03-10-2017, 11:30 AM   #4
My connection was slightly out of alignment with the access hole. It was not as bad as yours, but nonetheless, I could not connect my sewer hose or a 45 degree adapter. The dealer realigned the connector under warranty and it works great now.
RURVcrazy is offline   Reply With Quote
Old 03-10-2017, 01:36 PM   #5
Had the same problem with my legacy, I assumed it was a manufacturer defect that was special for my unit. I was not quick enough to take it back to dealer for correction. Now I just complain about it.
bhumphr196 is offline   Reply With Quote
Old 03-10-2017, 01:37 PM   #6
I guess I'm in the same boat.
Old 03-10-2017, 02:16 PM   #7
Dazed & Confused
M&K Hoffman's Avatar
Originally Posted by MERJnTravel View Post
Attachment 131366
Thanks,
Jonathan
Not an answer to your question, but I will say I work the honey dipper crew at our county fair where we service over 500 units. Run into a lot of those primarily on motorhomes.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
M&K Hoffman is offline   Reply With Quote
Old 03-10-2017, 02:45 PM   #8
Swampy's Avatar
Why not a bigger Hole?
I would suspect the hole is smaller for rodent control. Sewer hose is a major pathway for mice to gain access to your RV while camping.
........... Swampy
Swampy is offline   Reply With Quote
Old 03-11-2017, 09:27 AM   #9
Wolverine 1945's Avatar
........... Swampy
I am guessing if you are going to have a 10" opening,,, you need a 10" plug !!!
Looks like quality workmanship,,,
NOT !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-14-2017, 06:44 PM   #10
SS Groovette's Avatar
We have the same set up and find it perfect for clear elbow attachment. Helps monitor the coming out part of the black tank.
SS Groovette is offline   Reply With Quote
Old 03-15-2017, 07:52 AM   #11
I have no interest in seeing what comes out,,,
maybe because I know what we put in there ???
Old 03-21-2017, 06:03 PM   #12
Hah. Me too. Except when runs clear then we know we got it al! [emoji3][emoji3]
Old 03-22-2017, 07:09 AM   #13
I used to flush our pottie after we returned from each trip with our TT,,, in the yard next to the driveway,,, very little came out,,, bit there was always certain things leftover !!!
Old 03-27-2017, 05:29 PM   #14
7 Year Class A RV'er
Our 2015 360RB has a similar issue, but much less pronounced. Just a bit off center between the outlet and the opening. No reason for it that I can see tiger than FR's QC processes failing....again.
2015 Legacy SR340 360RB
black, tank
