Old 05-12-2017, 03:10 PM   #1
DrJAG's Avatar
Cable TV Grainy
After owning our Legacy for almost 2 yrs, I finally hooked up to cable TV. Got great picture on main TV, but picture on the other TVs was grainy, especially the bedroom TV. Picture using antenna is fine on all three TVs. Any ideas what to do to fix this. I did make sure the coax connections are tight. Also, I noticed two coax cables behind the video switch box that are not connected. One is gray and the other is black. What are each of these cables used for? Thanks!
-DrJAG
2015 Legacy 360RB with 2013 CRV toad. Retired USAF.
DrJAG is offline   Reply With Quote
Old 05-12-2017, 03:34 PM   #2
SeaDog's Avatar
the first thing I would check is to ensure your antenna booster is not on.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-12-2017, 04:45 PM   #3
Lacey's Spring, AL
formerFR's Avatar
I can't see how it would be the coach coax wiring or connections if the Antenna signal works well on all the TVs... if you have a BOMB(Coax/HDMI switch box) generally the coax from the outside connection comes into it, then out to all the TVs - the same with the Antenna signal.
Is the box pressed for 'CABLE' for each of the TVs?
with the switch box, it probably doesn't matter if the 'ON' button is pressed, as Cable doesn't require it, but it probably would not interfere with the Cable signal even if it is.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 05-12-2017, 04:59 PM   #4
bob213's Avatar
Did you switch the input from antenna to cable on the other tv's before doing a channel scan?
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 05-12-2017, 05:21 PM   #5
DrJAG's Avatar
I did make sure antenna booster was off, although there was no difference when it was on. Tried pushing all buttons on video box. Also selected cable on each TV and did new channel scan. I'm thinking it could be weak input signal or bad video switch box. Guess I could switch output cables and see if bedroom tv remains grainy or clears up.
-DrJAG
Old 05-16-2017, 07:39 AM   #6
Head Rambler
I could be a bad F connection at one end or the other of the cable.
Gotta go campin!
Old 05-16-2017, 06:59 PM   #7
captnrick3's Avatar
I've been fiddling with ours to try to duplicate that problem, so far I have not been able to. All TV's are the same.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 06-03-2017, 02:31 PM   #8
DrJAG's Avatar
Update.... finally at campground with cable. Hooked up and good picture on all three TVs. Guess I had weak cable signal previously.
-DrJAG
cable
