Old 08-02-2015, 08:21 AM   #1
Blacknchromehd's Avatar
City water hook up pressure
this is the first time we have been hooked up to city water as our trip west was off the pump and tank...unlike my old coach which had a valve to switch from tank to city this one does not...water pressure is not the best but not sure if the problem could be our campground in Sturgis....pretty full and might be low pressure from usage or location.
Blacknchromehd is offline   Reply With Quote
Old 08-02-2015, 06:50 PM   #2
I'm not sure what your question is but I'll try to help a little anyway. No, there is no valve or anything to switch between city or tank. It is very possible that you have a crappy supply coming from the CG. If it's really bad, I would just fill the tank and turn on the pump and use the coach to supply your water. Are you using a pressure regulator or filter? both of those could also effect your pressure. I do not use a filter in mine. If you have a filter in, take it out and see what happens.
-----IYAAYAS-----
Mons02035 is offline   Reply With Quote
Old 08-02-2015, 06:54 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
Sounds like low water presure at CG. I'd do as Mons02035 suggested. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
pressure, water
