Old 02-10-2019, 11:35 PM   #1
US MARINE
MarineOne's Avatar
Def refil pump install
The way the DEF tank in the Legacy is not mounted low enough to easily get all the DEF poured into the tank. It requires you to hold a heavy tank in the air and even then it can get messy when trying to get the last little bit out. To cure that issue I took a water pump and mounted it in the compartment next door, installed a switch, drilled two holes through the compartment bulkhead, ran the two hoses to suck and fill. The one with the PVC is small enough to fit into the DEF tank and the other long enough to go into a DEF refill bottle while sitting on the ground. It takes about 10 seconds to empty the refill bottle dry and no mess at all.
ID:	196536   Click image for larger version
ID:	196537   Click image for larger version
ID:	196538   Click image for larger version
MarineOne is offline   Reply With Quote
Old 02-11-2019, 06:12 PM   #2
US MARINE
MarineOne's Avatar
Originally Posted by MarineOne View Post
The way the DEF tank in the Legacy is not counted low enough to easily get all the DEF poured into the tank. It requires you to hold a heavy tank in the air and even then it can get messy when trying to get the last little bit out. To cure that issue I took a water pump and mounted it in the compartment next door, installed a switch, drilled two holes through the compartment bulkhead, rant the two hoses to suck and fill. The one with the PVC is small enough to fit into the DEF tank and the other long enough to go into a DEF refill bottle while sitting on the ground. It takes about 10 seconds to empty the refill bottle dry and no mess at all.
Sorry about the bad spelling. The system wouldn't let me edit. It should read ........is not MOUNTED low enough. and..... bulkhead, RAN the two........
Old 02-11-2019, 06:15 PM   #3
Mr. Dan's Avatar
The system will allow you to edit your own post within the first 120 minutes. After that, you can ask a moderator (use the Report function or PM a site team member) to turn on the edit function. I'll make these changes.
Dan
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 0
Old 02-11-2019, 06:43 PM   #4
Engineer of Crazy Train
ChooChooMan74's Avatar
Why not just go to a truck stop and fill up at the pump. Usually a lot cheaper.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 02-11-2019, 07:01 PM   #5
Delco Bobby's Avatar
Using the pump at filling stations isn't always easy with some motorhomes. On some the nozzle must be maneuvered with contortions .
MarineOne presents a solution that can help many motorhome owners.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 02-11-2019, 08:27 PM   #6
Thank you for the insight. Wouldn't know that there was a difference between the fill on my TV and motorhomes.
Locomotive Engineer
Old 02-11-2019, 08:55 PM   #7
Yup, the reason I know is because of all the posts I have seen due to owners having difficulty. Some had to make access hatches larger.
2018 Ford F-150
Old 02-11-2019, 09:52 PM   #8
Who Dares, Wins
doc73's Avatar
Not a mh but my chevy is under the hood on the passenger firewall.. Can't use the pumps because their hoses are only a few feet long..
It always amazed me how much effort they put into making these vehicles yet they never think about something so simple like filling the fuel, Def or changing the oil!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-11-2019, 10:00 PM   #9
RCW
Great mod! It's crazy where some of the fill points are on these. Just make sure to flush the pump with water after each use.
RCW is offline   Reply With Quote
Old 02-12-2019, 11:07 AM   #10
US MARINE
MarineOne's Avatar
[QUOTE=ChooChooMan74;2023161]Why not just go to a truck stop and fill up at the pump. Usually a lot cheaper.
Not sure where your DEF tank is but mine is on the right side of my rig and I have never seen a DEF pump on the that side. Its always on the left side. Truckers get a bit POed if you drive into the pump backwards. But rest assured if I ever find one on the right side as Im filling my fuel tank I will fill my DEF as well.
pump
