Old 04-26-2016, 09:03 PM   #1
US MARINE
MarineOne's Avatar
Dinette Storage
My wife wanted a pantry in the Legacy. So she pointed to the dinette and said "You could build a slide drawer in there couldn't you. YES DEAR. So here it is. Not AS hard as I thought but hard enough.
First off.... There are three and only three screws holding the bench to the slide. Remove them and pull the bench out.
Cut the seams in the end of the bench across the top end and down the middle panel seams. Pull staples and Fold the material back to expose the end of the bench. Pull off the cardboard face that exposes the 1x1s that form the arched end.
Pull the 30 or so staples out of the particle board that secure it to the frame. This is a huge pain in the arse but you will find a method. We used a punch to start a hole under the staple then pulled them out with a pointed hook and pliers.
Now you should be able to just lift the arched end off. On the side that faced the drivers seat we glued and screwed a 1x2 so that there would be an edge sticking out that side that you can use to open the drawer with.
Go talk someone into covering that arched end to match the seams in the other bench. This is where I tell you it took my wife over a month of run-a-rounds to finally get a very nice lady in the FR parts department to locate and order us matching fabric.
I ordered 500 lb capacity 30 inch side slides to put on the drawer They are very expensive and lighter weight slide may work just as well.
I built a box 38 inches long and as wide as I needed to to fit flush with the slides. I added 1x2s right on top of the bottom frame 1x2s to give the slides a place to mount.
Next we attached the slides to the bench and the box and slid it into place. Finally we mounted the face/arch of the drawer to the box
Seems to be perfect and my wife thinks I'm DA MAN. Click image for larger version
Name:	ImageUploadedByForest River Forums1461722463.466115.jpg
ID:	106234Click image for larger version
Name:	ImageUploadedByForest River Forums1461722490.801274.jpg
ID:	106235Click image for larger version
Name:	ImageUploadedByForest River Forums1461722512.162742.jpg
ID:	106236Click image for larger version
Name:	ImageUploadedByForest River Forums1461722548.208037.jpg
ID:	106237Click image for larger version
Name:	ImageUploadedByForest River Forums1461722563.624639.jpg
ID:	106238Click image for larger version
Name:	ImageUploadedByForest River Forums1461722587.192987.jpg
MarineOne is offline   Reply With Quote
Old 04-26-2016, 09:07 PM   #2
US MARINE
MarineOne's Avatar
Name:	ImageUploadedByForest River Forums1461722775.134443.jpg
ID:	106240Click image for larger version
Name:	ImageUploadedByForest River Forums1461722786.836840.jpg
More pics of the finished product. Hope to plug it back into the MH tomorrow if the tornadoes don't get in our way.
Old 04-26-2016, 09:11 PM   #3
rmac04401's Avatar
Very nice job
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-27-2016, 10:11 AM   #4
captnrick3's Avatar
Originally Posted by MarineOne View Post
Attachment 106240Attachment 106241
Wow, you are DA man. I have been studying this project for the past year and the need for matching fabric kinda kept me from starting out on it. Very impressed. After the upcoming summer trip to Canada, I can see a project.
Thanks for posting
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 04-27-2016, 12:57 PM   #5
US MARINE
MarineOne's Avatar
Name:	ImageUploadedByForest River Forums1461779343.539196.jpg
ID:	106313Click image for larger version
Name:	ImageUploadedByForest River Forums1461779360.490568.jpg
ID:	106314Click image for larger version
Name:	ImageUploadedByForest River Forums1461779378.256779.jpg
ID:	106315Click image for larger version
Name:	ImageUploadedByForest River Forums1461779400.017347.jpg
Installed and working well. One word of caution. Be careful about placement of the drawer face. It appears the slide slopes slightly down (toward the floor) when OUT. If the drawer face is even a quarter inch below the top of the bench it will drag the floor when it's about halfway out and pulling the slide in might get ugly. We figured it out before we slid in. We raised the drawer face to right at level and it works great slid out. Slid in you start dragging about 8 inches out. If that becomes an issue for you just shim the bench to raise it a half inch and it will slide all the way to the sofa while slid in.
Old 04-27-2016, 01:11 PM   #6
Don't Camp Enough
DSMURPHY's Avatar
Originally Posted by rmac04401 View Post
Very nice job
x2
'2016 Rockwood 8288WSA
'2016 F-350
DSMURPHY is offline   Reply With Quote
Old 04-27-2016, 05:43 PM   #7
captnrick3's Avatar
Is there a latch of some sort to prevent them from opening?
2015 Legacy 340KP
2012 Wrangler Sport
Old 04-27-2016, 08:30 PM   #8
US MARINE
MarineOne's Avatar
We had two 10 pound larches we were going to put on the inside of the box and attached to the frame , like every other drawer in the kitchen, BUT. As I hinted to earlier....when the slide is in and you are traveling the drawer CANT open more then a few inches before it stops as it hits the floor. So far it hasn't come open at all. If we run into that problem we will install the two latches on the face of the drawer.
Old 04-28-2016, 07:48 AM   #9
Blacknchromehd's Avatar
nice
I am in no means able to do work like this and going to look at someone who can do this for me...its an excellent idea and would look great on mine...I have the 360 RB so mine is a tad different...any more photos of the job you can send me?
Blacknchromehd is offline   Reply With Quote
Old 04-30-2016, 07:45 AM   #10
US MARINE
MarineOne's Avatar
Im attaching all the pics I took that I didn't attach before. If you have any specific questions just give me a shout. Believe me, Im not a carpenter and not skilled at any art. Once you get into it and see how they put it together it doesn't take a lot to see how you can make the project work. The key to this was being there with the guy doing the upholstery so I cold relate to him what I needed. He really only had to sew two seams that looked like the ones on the other bench but there were a LOT of staples when you went to put the bench back together. My father-in-law, who has been camping all his adult life and worked on them for a long time, suggested that I could put the slides on the bottom of the drawer and that might work even better. It might have. So that is another way to do it. It would sure eliminate the need to get the width of the drawer EXCTLY right between the slides......and it would give a bit more support to the bottom of the drawer. Maybe next time.
ID:	106484   Click image for larger version
ID:	106485   Click image for larger version
ID:	106486   Click image for larger version
ID:	106487   Click image for larger version
ID:	106489   Click image for larger version
storage
