Old 04-06-2018, 09:37 PM   #1
Engine battery switch
For the one that has problem where engine shut down. I found the cause, the battery engine switch get losses in the connection. Apparently vibration lossen the nut and bolt that makes a switch connection. Check out by putting your light on and move the switch back and forth you see lights on and off. That the problem.
donritam is offline   Reply With Quote
battery, switch
