Old 03-23-2017, 07:25 PM   #1
Engine Oil Change Cost
Hi Folks,
I contacted the local RV dealers about an oil change for our Legacy. The quote I was given was $380.00 for oil and a filter.
Is there something special the requires more labor for a MH oil change? I figure the oil and filter should be under $100.00. Labor should be less then 1hr, $135 at the most expensive shop.
Whats up?
Joe
2014 FR Legacy
2006 Jeep Unlimited
hbjoe3 is offline   Reply With Quote
Old 03-23-2017, 07:34 PM   #2
Kenny kustom's Avatar
You forgot to add the pain in the butt tax...
Plus, it takes up a lot of space for such a low profit job, as an oil change.
Try an independent garage, one that would do it in their parking lot.
2017 Dynamax Isata 4
Old 03-23-2017, 07:45 PM   #3
Berkshire 390QS
NO3putt's Avatar
Why take it to an RV dealership. Take it to an authorized feightliner/cumins dealer where they can do all the required maintenance, i.e. Lub the joints etc. We learned that our RV dealer just drove the units to a feightliner shop and charged a fee for that too.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 03-24-2017, 09:23 AM   #4
ceedog's Avatar
Take it to a FL dealer & ask for the PM-1 maintenance.
That will take care of the oil change.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 03-24-2017, 09:32 AM   #5
dndnva's Avatar
I use my local Freightliner service center and pay around $450 for the annual service. Doesn't include generator.
2016 Legacy SR340 KP (340HP, 2500 Allison)
Toad: 2013 Wrangler Unlimited
dndnva is offline   Reply With Quote
Old 03-24-2017, 09:37 AM   #6
ahh...remember how good you feel when you put diesel in that tank. Time to pay when it comes to oil changes and other maintenance. A gasser would cost $60 if you do it yourself.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 03-24-2017, 09:57 AM   #7
W5CI's Avatar
You can always do it your self
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 03-24-2017, 01:31 PM   #8
I have a 2012 Ram 3500 with a Cummins. It takes 12 qrts of oil plus a Wix filter and I have never paid more than $75.00 for a oil change. If you can do it yourself it's not that expensive. Some of the newer trucks with the 6 liter engines take at least 8 qrts of oil and the manufacturers require full synthetic oil so if you can do it yourself it's almost a wash as far as the cost of a oil change. If you can't then your going to pay.
No more shoveling is offline   Reply With Quote
Old 03-24-2017, 03:37 PM   #9
7 Year Class A RV'er
You're also forgetting it takes 18 quarts of oil at about $4.00 per quart, not including the generator. I do them both at the same time and use the Freightliner shop. They know what they're doing, check it all out, lube, etc. and for the record, shop rate for motor home repair is closer to $130 per hour at every shop I've seen.
2015 Legacy SR340 360RB
Old 03-24-2017, 04:34 PM   #10
When I purchased our used Chevrolet Duramax diesel(8860 miles) in 2016, the dealer agreed to change the oil & filter for the first 50,000 miles free of charge. After that I will change it myself, not a difficult job at all. It holds 10 qts. of oil.
Walholler is offline   Reply With Quote
