Old 05-06-2015, 06:35 AM   #11
TURBS's Avatar
Originally Posted by Herk7769 View Post
Can you check the voltage being delivered by the generator while both air conditioners are running? If the 2nd AC is on the same circuit as the block heater outlet (and that is all that is there - there may be other things not working with that breaker popped), you may be pulling too many amps on that circuit if the voltage is low and the AC compressor/fan kicks on.
Considering you'd probably not use the a/c while also using the block heater " different seasons" this is a good possibility.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-06-2015, 12:55 PM   #12
I can check that. After I shut off the block heater breaker the second AC unit still worked. Also, does this mean that the block heater is also powered by the generator and or shore power when plugged in? I thought the block heater would only work if I plugged in a cord to that pigtail?
-----IYAAYAS-----
Mons02035 is offline   Reply With Quote
Old 05-06-2015, 12:58 PM   #13
7 Year Class A RV'er
Just plug the block heater pigtail into the adjacent outlet.
electric, electrical, power
