Old 10-10-2018, 03:02 PM   #1
Fasteners
Just wondering if anyone has suggestions on how to keep screws from backing out for closet racks, towel racks, etc
Thank you.
Terry Carter
2018 Georgetown XL 369DS
Terryhcarter is offline   Reply With Quote
Old 10-10-2018, 03:29 PM   #2
What's causing them to back out? Are they stripped? If they are backing out, maybe try Loctite. If they're actually stripped, SuperGlue or similar adhesive may work for holes that already exist. Many on this forum recommend Command Strips rather than putting new holes in their camper walls.
Skip12 is offline   Reply With Quote
Old 10-16-2018, 08:25 AM   #3
Lacey's Spring, AL
formerFR's Avatar
I've often found that a simple toothpick pushed into the screw hole will provide a new 'grip' for the screws to hold into... you can also add some wood glue in the hole as well.
formerFR is offline   Reply With Quote
Old 10-16-2018, 09:23 AM   #4
jeff64's Avatar
Try taking 1 or 2 of the smallest size nylon tie wraps and bend into "L" shape and insert into the hole before you put in the screw, they won't disintegrate. Clip off the tails once you seat the screw Beyond that its "molly time"
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-16-2018, 11:19 AM   #5
Head Rambler
If they're not stripped and are just backing out, some clear (or your favorite color) fingernail polish will help keep them from backing out. Locktite is a good idea, but clear nail polish is much cheaper and comes in smaller quantities.
Gotta go campin!
Old 10-16-2018, 03:59 PM   #6
Thanks to everyone for the suggestions
After we get warranty work done i will try the ideas given.
Many thanks,
Terry
Terry Carter
