Old 09-21-2017, 01:07 PM   #1
Generator not charging batteries
I recently had the generator running while using the microwave and a few overheard lights. I turned the roof fan on and everything dimmed for a second. From that point on the generator would not charge the battery bank. I can still charge the batteries via electrical outlet. Any ideas what happened? Thanks for your help.
Legacy Owner is offline   Reply With Quote
Old 09-22-2017, 07:38 AM   #2
Lacey's Spring, AL
formerFR's Avatar
check your Generator breaker, on the generator itself, it may have tripped... your inverter may still power your micro and lights, and your roof fan may have taken the batteries down a little too much, causing the dimming effect...
even the generator is 'running' does not mean that it is providing power - if your Magnum inverter panel shows 'inverting', then no, it is not providing power... if it says 'charging', then yes it is... : )
I wish there was an 'alert' provided for when the generator breaker has tripped, but alas, there is none, other than looking at your Inverter readout...
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 09-22-2017, 11:00 AM   #3
Thank you. Any ideas where the generator breaker is located?
Old 09-22-2017, 11:04 AM   #4
bubbles's Avatar
Like formerFr said, on the generator.
Old 09-22-2017, 11:05 AM   #5
SeaDog's Avatar
They are located in different places on different generators you will have to look. Even if they don't looked tripped reset them anyway.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-22-2017, 11:05 AM   #6
Yes, sorry I missed that. Going to look now.
Old 09-22-2017, 11:06 AM   #7
Thank you!
Old 09-22-2017, 11:12 AM   #8
SeaDog's Avatar
Originally Posted by Legacy Owner View Post
Thank you!
If that means you found the breakers and the problem is solved great!
Retired Navy
batteries, charging, generator
