Old 02-25-2017, 04:04 PM   #1
Generator Oil level question
Help ... this is a picture of my generator. I do not see any fluid. Needs to be filled?
Legacy Owner is offline   Reply With Quote
Old 02-25-2017, 05:31 PM   #2
bubbles's Avatar
Not familiar with that genny but the tank appears to be for coolant (water/antifreeze) not oil. The oil fill cap should have a dipstick attached or at least something attached to denote level. The coolant level quantity (hot/cold) is specified on the black strip. Just a guess.
Old 02-25-2017, 05:41 PM   #3
Thank you!
Old 02-25-2017, 07:22 PM   #4
sgtlm17's Avatar
The white cap should be coolant the yellow cap should be your oil.
Check out these two videos
https://youtu.be/CxqkHAAH818
https://youtu.be/0LB5ZhvhXas
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 02-27-2017, 12:39 AM   #5
captnrick3's Avatar
Generator when cold should have an 1 1/2" or so of coolant showing in the tank, a bit more when hot. The yellow cap is the oil dipstick. You will likely find that the genny does not use any oil between changes, however it is prudent to check it once in a while. I just finished my full annual service and we had about 125 hours, it had not consumed any measureable amount of oil.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
generator
