Originally Posted by DrJAG
Brought our new RB home yesterday. Now get to figure out where to store everything and do a few mods. Dealer wasn't sure about the sound bar operation. ... would appreciate someone explaining how it works. Not sure mine is even powering up.
Check to make sure that the plug is connected in the back of the soundbar. it is easy to get disconnected....The unit does come off.. you just have to lift up on it, it sits on two tongued prongs..Easy on and off. Next check to see if the plug is connected to the power receptacle. One of these may be your problem.
Soundbar has two functions: 1) works with the television and 2) works as a bluetooth player for a music device.
To use the soundbar with the TV, ensure that your audio settings on the TV have the output set to external. This channels the sound from your TV to the soundbar. There a RCA connections on the back that make this happen
To use it as a blue tooth device, it needs to be paired. Check your device to ensure that you can see it. Make sure you are in bluetooth mode with the source button. This also applies to the mode for the TV, make sure that you are in the right source mode to operation. I think that it is input 1.
Your rig looks big in that driveway!! NICE!!!
