Old 02-18-2015, 06:46 PM   #1
mmarchand's Avatar
Headlights
My headlights do not appear to illuminate the road correctly unless I have the bright lamps on the low beams just light up about 10' in front and that is with fog lights on the bottom ? I turn the dial all the way too the right and push the switch then the brights have to be activated to have sufficient light ? Any thoughts or suggestions please !
mmarchand is offline   Reply With Quote
Old 02-18-2015, 08:45 PM   #2
psw757's Avatar
That is odd.
I haven't had any issues with the headlights but I did have to adjust my drivers side fog light as it was shining a bit high in the face of oncoming traffic. Was easy to adjust.
Keep us posted on the headlight situation.
psw757 is offline   Reply With Quote
Old 02-18-2015, 11:31 PM   #3
captnrick3's Avatar
Wish I could help. Have not driven at all at night yet. Coming attraction. Thanks for posting, we will be checking this out soon.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 10-03-2015, 01:43 PM   #4
Jdotsonsc's Avatar
Having same problem on my 2016 360RB. Had low beam adjusted up, but still not really satisfactory. High beams work great.
Jdotsonsc is offline   Reply With Quote
Old 10-18-2015, 07:30 PM   #5
W4JJ's Avatar
I have the same issue with the low beam being very dim and inadequate. I suppose this issue requires further review.
Jack
2014 Legacy 340BH
Arlington, VA
W4JJ is offline   Reply With Quote
Old 11-02-2015, 09:16 PM   #6
Blacknchromehd's Avatar
Made some serious adjustments to mine tonight....also reworked the driving lights as the left side was way low and to the left....re worked brackets and location
Blacknchromehd is offline   Reply With Quote
Old 11-03-2015, 08:35 AM   #7
mmarchand's Avatar
Yep had mine adjusted by the dealership still inadequate in my opinion did you adjust them yourself ? I believe some adjustment will cure some of my issue but I am considering different lamps for the low beams
Old 11-03-2015, 08:39 AM   #8
i also made some adjustments to the running lights which helped as well. Also looking at better bulbs for the low beams...have to be careful about heat and the plastic lens..
Old 11-03-2015, 01:16 PM   #9
7 Year Class A RV'er
Drove mine after dark for the first time and have to agree. Of course, it was raining, so much worse. Fog lights were very good. Is only the upper lens of the headlight supposed to light?
"Conceptumator" - Orlando, FL
2015 Legacy SR340 360RB
2014 Jeep Wrangler Unlimited
Old 11-03-2015, 04:39 PM   #10
Jdotsonsc's Avatar
Taking mine in for warranty work on the 9th. Will have voltage checked and upgrade to ultra bright bulbs if necessary. Will let you know how that helps.
light
