Old 08-15-2014, 09:43 AM   #11
If you have a Gerrard HW heater you do not have a by pass.
Old 08-15-2014, 09:46 AM   #12
Herk7769's Avatar
Times a million...
HAM CALLSIGN - KC3FFW
Old 08-15-2014, 10:00 AM   #13
Joe a couple if thing. First please add what rig you have to your profile. When I'm on my phone it doesn't show up.
If you have low WP at the site you are try running the water pump. It should give you the WP you need to run the WH. Look for a shower head that mixes air in it. There are a couple out there and they help a lot. Read the old posts on the forum about the Gerrard WH. There is tons of info posted and more than I can relate in this post. Are you using water from your tank or the campground? I know that in AZ some places use a cistern and that could be the problem. If the water is warm coming in it is almost impossible to get the temp right as there is not a thermostat in the water line. If that's the issue call Garrard and they can send you a BTU limiter that closes off half of the burners. We used them before the temperature dial they use now. Click image for larger version
Name:	ImageUploadedByForest River Forums1408114849.670900.jpg
Old 08-15-2014, 10:13 AM   #14
Phat Phrog Stunt Crew
elind's Avatar
At our Wildcat plant tour we told that the on demand hot water heater were discontinued for now in the Wildcats. It sounded like users needed to learn how to use it. It delivers hot water a little different than the standard hot water heater. A steady flow of hot water when using it is the key to it.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-16-2014, 12:22 PM   #15
Thanks folks!
We are in a 2014 FR Legacy and currently are hooked up to CG water. Whenever we run the hot water it sounds like the pump is running, but I have it switched off. I am using a pressure regulator. Seems water pressure is low.
It is not just the shower that is a problem, any hot water use will vary considerably, it just is most uncomfortable in the shower.
2014 FR Legacy
2006 Jeep Unlimited
hbjoe3 is offline   Reply With Quote
Old 08-16-2014, 12:59 PM   #16
Herk7769's Avatar
Originally Posted by hbjoe3 View Post
Thanks folks!
Try removing your water pressure regulator. It may be "buzzing" from corrosion in the valve and reducing your water pressure too much.
Old 08-16-2014, 01:07 PM   #17
Herk,
It is brand new, used about 15 days. I do have a spare so I will swap them out.
Joe
2014 FR Legacy
2006 Jeep Unlimited
Old 08-16-2014, 01:09 PM   #18
Herk7769's Avatar
Herk,
Joe
Trying to think about what could cause the "motor" noise.
Most likely is not a new regulator...
Still thinking...
Old 08-16-2014, 01:20 PM   #19
Does the water heater have a fan to exhaust the fumes? Could be that is what you are hearing.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 08-16-2014, 01:31 PM   #20
Vibe,
I don't think there is a fan, it seems to vent right out the side of the MH. Could it just be burner noise? The pump is on the other side of the MH so I don't think that is it, but sound similar. I'll have the DW run the HW while I look outside.
2014 FR Legacy
2006 Jeep Unlimited
hot water, show, shower, water
