Old 01-06-2016, 03:33 PM   #1
House Battery Life
Happy New Year!
With fully charged house batteries how long can I expect them to last with just the refrigerator running?
Thanks,
Joe
2014 FR Legacy
2006 Jeep Unlimited
hbjoe3 is offline   Reply With Quote
Old 01-06-2016, 10:47 PM   #2
captnrick3's Avatar
24 hrs. tops. We dry camp a lot (out in open desert right now). I installed 500 watt total solar panels that provide all we need during the day. Auto Gen Start is set to start at 12.0 volts and run for two hours. Usually starts every mornimg, we usually run it manually during dinner to run the micro/oven. So far the residential fridge has not been the train wreck I feared.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 01-06-2016, 11:29 PM   #3
Usually Confused Member
emm-dee's Avatar
24 hours????? I've left my refrigerator on (via propane) for over two weeks. Battery still had plenty of power to run the power tongue jack (a heavy power user).
What type of refrigerator power is there that would drain a battery in 24 hours.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 01-07-2016, 12:06 AM   #4
Kenny kustom's Avatar
Residential..?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-07-2016, 04:54 AM   #5
Bluepill's Avatar
My Samsung 25 Cu.Ft French Door refrigerator uses an average of 2KWH per day measured on the 120 volt side. This is with inside temperatures averaging 72 degrees. It will use more as the temperature goes up. That equates to 180 Amp. Hr. of battery use every 24 hours. (180 x 12 volts x 92% efficiency for the inverter). Since you do not want to discharge your batteries more than 50%, it requires 360 Amp. Hr. battery capacity just for the fridge. The size of your battery bank and the exact usage of your particular fridge will determine your usable run-time.
2008 Itasca Meridian 37H
Old 01-07-2016, 09:51 AM   #6
captnrick3's Avatar
Residential fridge I a whole different ballgame from propane. Last 4 rigs were propane. I would rather have that if I had my way.
2015 Legacy 340KP
2012 Wrangler Sport
Old 01-07-2016, 09:53 AM   #7
captnrick3's Avatar
Originally Posted by hbjoe3 View Post
Happy New Year!
Thanks,
Joe
Looks like your rig is exactly like ours so I answer based on actual experience.
2015 Legacy 340KP
2012 Wrangler Sport
Old 01-07-2016, 10:39 AM   #8
aeroshots's Avatar
Same here, 24 hours give or take. Some obvious but stated factors --how often you open the doors and how it is loaded. Nearly full and it will last the longest. I put those gell ice packs in the freezer making it a cooler so to speak and that helps.
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 03-14-2017, 07:15 AM   #9
srappleby's Avatar
We are going to an air show next month and will be our first experience with dry camping. We have been practicing water conservation (not very well) but I'm worried about battery life overnight during quiet time with no generator. Sounds like I can expect my inverter and batteries to get through the 8 hours or so just fine. Any tips or suggestions?
-Steve
2014 Legacy SR300 340BH
2010 CR-V Toad
srappleby is offline   Reply With Quote
Old 03-14-2017, 08:20 AM   #10
CC75's Avatar
Cool down the RV residential fridge the night before you leave, with all controls on max. Pre-freeze water bottles in your sticks and stones house (bottles take at least 24 hours to freeze), and place them in the freezer of camper. Try to fill the freezer with pre-frozen bottles around your food. The ice will stabilize the temperature in the freezer as you open and close the door, thereby limiting the number of times the compressor has to cycle on. Place many frozen bottles in the fridge as well. Since the bottles will be as hard as rock, arrange them in a manner that will not destroy your fridge during travel thru bumpy roads. I place them on a dish towel in the very bottom drawer of the fridge. When ice melts in the water bottles in the fridge drink them and move frozen bottles from freezer down to fridge.
Move the temperature controls to recommended on the morning of your trip.
The start and subsequent running of the compressor is where most of the power is used. If you minimize the cycle time of compressor you will minimize the draw on your batteries. My whirlpool fridge uses less than 1 amp for the fridge's fan when the compressor is not running. Of course the compressor reference only applies to residential fridges. The frozen bottle use to manage temperature applies to both types.
CC75 is offline   Reply With Quote
battery
