Old 12-02-2015, 03:27 PM   #11
Originally Posted by conceptumator View Post
There is the switch described on the 2015 Legacy. Just a toggle to the left of the steering wheel. You can level it without dumping the air (I've done it). The "excess slope" message just indicates the system couldn't find the preset level point and the hacks are all the way out. I get the same message from mine when I level in our driveway, but I checked it with a level and it's so close to level it doesn't matter. Letting the air out of the suspension just lets the step be closer to the ground. They do tell you to be very careful if you move the coach with the bags deflated as the tires can rub. Probably want to do a walk around and gave a spotter as you pull it in the first few times.
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Sounds like the switch I have. So it's a dual purpose switch? Leveling and dumping completely?
jhall1957 is offline   Reply With Quote
Old 12-02-2015, 03:59 PM   #12
Blacknchromehd's Avatar
Air
Originally Posted by psw757 View Post
As far as I know the dumping of air can only be done in conjunction of using auto levelers which won't work out of neutral.
Is there a manual dump valve that I am unaware of?
Yes on my dash to the left is a dump switch that allows me to let all the air out of the bags prior to me leveling the unit
Blacknchromehd is offline   Reply With Quote
Old 12-02-2015, 04:02 PM   #13
air
I always let the air out of mine at the end of the day camping or storage...always put it back on to fill the bags and raise the unit. I put it down first prior to leveling...saves me tons of issues.
Old 12-02-2015, 04:03 PM   #14
ride
Here is a pic of mine lowered on the air...no need to keep the bags filled when its sitting.
Old 12-02-2015, 04:26 PM   #15
7 Year Class A RV'er
Switch is dump only. Then you level. I try to always dump before leveling, just forget sometimes. If you dump the air after leveling, you'll want to raise the jacks and level again.
Old 12-03-2015, 10:43 AM   #16
psw757's Avatar
Can someone post a picture of the switch? I don't think we have one.
I've been dumping air via the auto level system which dumps it all prior to the jacks moving.
psw757 is offline   Reply With Quote
Old 12-03-2015, 10:56 AM   #17
My jacks don't dump the air - they work with or without dumping it. I can also dump the air if I just want to lower the coach when parking to get the step down a bit (no need to level). Here's a photo with a red circle around the switch.
Old 12-03-2015, 11:06 AM   #18
psw757's Avatar
If it's that lever that I see through the opening in steering wheel, we definitely don't have that on our 2014.
Old 12-03-2015, 11:09 AM   #19
That's the one. Since your unit sounds like it kneels automatically with the levelers, that may be the reason you don't have one. Guess they decided to separate the two functions. I just get senile about half the time and forget to dump the air before I level, then I have to start all over. Once I dump the air, I also make sure to put the switch back in the normal position so I don't forget before I drive away. The engine is off then, while I'm leveling, so the bags stay deflated.
Old 12-03-2015, 01:18 PM   #20
DrJAG's Avatar
I have a 2015 RB with the Auto/Manual switch and dump the air by moving it down to the Manual position and air up by moving it up to the auto position. Why is it labeled Auto? Does the Auto position do something else or does it simply mean the air pressure to each corner is adjusted automatically while driving?
-DrJAG
2015 Legacy 360RB with 2013 CRV toad. Retired USAF.
DrJAG is online now   Reply With Quote
