Old 05-18-2018, 09:39 PM   #11
RSchleder's Avatar
Originally Posted by hbjoe3 View Post
Forgot to mention, under the unlimited plan the Jetpack is limited to 15GB then it gets throttled, slowed down big time. According to the last Verizon person I talked to your phone can be used as a personal hot spot and it will not be throttled. Makes no sense to me, I used the jetpack until they told me they were going to slow me down, then I switched to the phone and continued at full speed.
I think this would hurt you if you were depending on this plan for work, I don't think you can be using the phone as a hot spot while you are talking on that same phone.
Both the iPhone AND the hotspot get their speed drastically reduced at 15 GB when being used as "hotspots. Your iPhone will have it's speed reduced also when using it as a internet device (not hotspot) at 22GB.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-18-2018, 09:43 PM   #12
CRL1's Avatar
If youre a FMCA member they have a deal with Verizon and Sprint for Internet access.
CRL1 is offline   Reply With Quote
Old 05-19-2018, 01:23 PM   #13
VZ on the road
We have made two major cross country trips from CA to the East Coast back over the past 2 1/2 years with VZ! That includes Northand South zig zags visiting relatives and friends! Weve not had a problem yet with VZ! We have had issues with a few RV parks with poor internet connections! I use my cell phone connected to our notebook and no problems at all! Weve even used VZ on trips to Germany this past year (special OS billing pkg while there) without any problems! Dan & Gerda
Dan n Gerda is offline   Reply With Quote
Old 05-19-2018, 01:36 PM   #14
bikendan's Avatar
We like our T-Mobile 55+ plan, using the phones as hotspots for our tvs and tablets.
Equalizer WDH
Old 05-19-2018, 01:41 PM   #15
Use pdanet app to get around 15 GB limit
Originally Posted by jvenditte View Post
I am investigating Verizon's unlimited cellular phone plans with a jetpack (used for a hotspot vs. using a phone as a hotspot) with a signal booster (extender). Want to improve my internet access for work while on the road.
Is this a good plan? Looking for recommendations. Thank you
To get around the limit of 15 GB of 4G hotspot per month, using an Android phone (not a jetpack), install pdanet. It's a third-party hotspot app with 5 million users. Try it for free, then you can pay $7 for the full unlocked version.Go to pdanet.co for information.
Run pdanet instead of the phone's internal hotspot, and you have unlimited 4G hotspotting. You can run the hotspot on wifi, USB or bluetooth.
It only runs wifi on the 5 GHz band, so if you have an old laptop that only has the lower frequency bands, you have to use a USB cable from the phone to the laptop. I've been running it that way for over 6 months now, and it all works perfectly. My tablet doesn't have the 5 GHz band either, so I use Verizon's 15 GB through the normal phone hotspot for the tablet.
Google and Verizon used to block third-party hotspots from the play store, but they lost a class action lawsuit because blocking them was a violation of Verizon's contract with the FCC (Federal Communications Commission). Google for information.
Another poster said that Veizon throttles the phone at 22 GB. That happens only when the tower you are on is congested.
2018 Coachmen Viking 21RD
2012 Ram 1500 5.7L Hemi 4x4
Full-timing since October 2017
johntaylor is offline   Reply With Quote
Old 05-19-2018, 01:51 PM   #16
Dahagen
I had Verizon for many years with the 15 gig Mi-Fi. Last fall I switched to T-mobile's 55+ plan with unlimited usage. It is faster than Verizon and seems to have better coverage. I went from Idaho's mountains to Arizona's deserts to Florida's resorts with no problems. I tipicially use about 25 gig with my two smart phones with hotspots, two tablets, and one computer. AND I saved $40 a month.
dahagen is offline   Reply With Quote
Old 05-19-2018, 02:15 PM   #17
We have Verizon with 4 lines, unlimited data, only $40 per line if you use autopay. We use it frequently both at home and camping and it works great. We do occasionally stream video, and have never noticed a throttle back. Often it is faster than the campground WI FI. Many campground WI FI systems are not very good, but they seem to be generally getting better.
We just use the cell phone as a hot spot, rather than paying an extra fee for another device. This works fine, but you need to have the phone plugged into charger, as power consumption is quite high. If you need much WI FI and also need access to your phone, the Hot Spot might be worth the extra fee.
jjuscg is offline   Reply With Quote
Old 05-19-2018, 02:45 PM   #18
gectisme's Avatar
It worked for us and I had to have internet to do my job and be able to do our 21 month trip. We used the MiFi 6620l Jetpack for 2 years with decent performance. I also need good bandwidth to be able to do my job and I had no issues with the jetpack. The nice thing about the 6620l is it has an external antenna port and in fringe areas I would connect up a directional antenna on a post out side to get better bandwidth.
My DW did all the trip planning and always called ahead to see if Verizon had decent coverage so for the most part when I needed to work, we stayed at a RV Park that we knew had Verizon coverage. It was eye-opening to find many places that had no clue about the Verizon coverage so we would go on the web and check campground reviews. The campground reviews were usually spot on when they mention the cell coverage.
I just ended my plan that I leased from a 3rd party company, unlimited data, no cap, no throttle for $120 a month. To me it was a good deal.
The version 4G jetpack can connect up to 15 devices. Is this essentially a router?
Yes, it is a router.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper).
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 05-19-2018, 04:04 PM   #19
My Verizon plan says 22 gb then throttle. On a recent trip to Naples Florida, I hit the 22gb limit. I got notice from Verizon I was nearing the limit. But I experienced no slowdowns after exceeding the limit.
One thing Im gonna try next time is to turn off and automatic updates of apps and also turn off all apps that have continuous access to my location like google maps when Im not going to use it.
We would definitely exceed the limit monthly if me and my wife are not using campground WiFi which is more than likely the case. But I was able to stream movies after I exceeded the limit.
I guess we would have 44g using my wifes and my iPhone as hotspots. Also I have a Verizon mifi so I guess I could enable it when Im out.
Ive had trouble with sprint in the past so Im not sure about switching but if I hear more good reviews like the previous poster, I might go for it.
FYI
MikeRP is offline   Reply With Quote
Old 05-19-2018, 05:05 PM   #20
Originally Posted by dalford View Post
Im not sure of your definition of work while on the road. Are you on the road a lot or are you talking while camping and still having to work?
The 15-20 GB throttle back is per hotspot device. All the throttle back rates are per device. So, if you use a dedicated hotspot and reach the limit you could always use your phone as a back up hotspot. You married? Then your DW would have 15-20GB of hotspot usage before limit.
Unless you are streaming a lot of video for work I doubt you would ever reach the throttle back limit....
Also, look into Beyond Unlimited with Verizon if you need more...
Verizon Beyond Unlimited still throttles back after 15 gigs
Bnrc73 is offline   Reply With Quote
service
