Old 08-28-2016, 01:56 PM   #1
DrJAG's Avatar
Leak in black tank drain line
Started getting our Legacy ready for next trip, after not using it for last three weeks. Noticed a small splat of dried blue liquid inside the water/drain connection compartment. Found this pinhead size drip coming from black tank drain pipe. As shown in the picture, it appears to be coming from the connection between two pipes. We have had our Legacy for over a year and this has not occurred before. Fortunately I thoroughly flushed the black tank after last use. Then I put in a few gallons of water and some blue tank treatment, which is where the blue came from. I am hoping I can fix this by putting ABS sealant around the joint. I am still looking at it to make sure that is where the leak is vs running down from higher location. Any thoughts? Also, can someone explain to me how the drain piping is connected to the black tank, especially commenting on the hose clamp? Guess my Google search skills are lacking.
Thanks. - Dr JAGClick image for larger version
Name:	ImageUploadedByForest River Forums1472410414.538027.jpg
2015 Legacy RB, 2013 CRV toad. Retired USAF. Sent from my iPad using Forest River Forums
-DrJAG
2015 Legacy 360RB with 2013 CRV toad. Retired USAF.
DrJAG is offline   Reply With Quote
Old 08-28-2016, 07:12 PM   #2
aeroshots's Avatar
I think the challenge in sealing it without disassembly is getting it dry. My first thought is empty the tank of course, then somehow get a blower to move air through the tank system to dry. Then maybe try something like this
https://www.amazon.com/PR-1422-Aircr.../dp/B00DJAVVFQ
or
https://www.amazon.com/Atlas-Epoxy-P...ol+leak+sealer
My Legacy is at a dealer for some work, or I'd look closer at the connections.
Good luck.
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 08-28-2016, 08:08 PM   #3
DrJAG's Avatar
Thanks for the suggestions. Still pondering this. Best way is to replace everything, but don't think I could get that done before our next trip. I think I could get it dry by and then use ABS glue or Goop for plumbing. I could also use JB Weld Waterweld, which doesn't require it to be dry. Also considering wrapping it with self sealing silicone tape.
-DrJAG
Old 08-28-2016, 08:16 PM   #4
DrJAG's Avatar
Here is another picture. Note the excess glue on the joint below the one that has the leak.Click image for larger version
Name:	ImageUploadedByForest River Forums1472433349.551216.jpg
-DrJAG
Old 08-29-2016, 01:03 PM   #5
I had a leak in my ABS grey tank and consulted with the Service tech at my dealer. He recommended this product pictured below. It worked great.
You may want to check with your service guy if available or contact the MFG. I've never seen a hose clamp like that used for making up. waste tank seals. I'm wondering if it is a sign of a previous repair.
Name:	ABS Tank Repair Kit.jpg
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 08-29-2016, 02:04 PM   #6
DouglasReid's Avatar
Most likely a cracked coupling when it was installed with the hose clamp to hold it together. That is what it looks like to me, particularly sinc the hose clamp has black stuff on it, like some of the ABS cement Ive seen.
One possible solution is to remove the coupling *CAREFULLY* and after it is off, replace it with a flex coupling (called a Fernco) in the plumbing stores. It is rubber and uses a hose clamp on both ends. It will seal VERY well!
It is a very tight fit so use liquid dish soap to lube both pieces of pipe and inside the coupling so it slides on more easily. tighten the clamps and you are done
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 08-29-2016, 02:49 PM   #7
DrJAG's Avatar
Thanks for the responses. Regarding the clamp, there is also one on the pipe from the grey tank. In googling, this, I found references to clamps being used to connect the drain pipes to the tank. Also, it's hard to see in the pictures, but the clamp does not appear to be around the section of pipe that is leaking. It is around a pipe with a slightly smaller diameter. Maybe some other Legacy owners could see it theirs are connected this way too.
-DrJAG
Old 09-01-2016, 07:21 PM   #8
Both of mine are that way also. I looks to me like, to make the connection between the ABS pipe and the tank, a slip-to-male-thread adapter, glued to the ABS pipe, was inserted into a larger sleeve that is molded as part of the tank. Then, either the sleeve was heated (my guess), or possibly some sealant applied to the joint, or both, and then the hose clamp was tightened to press the tank sleeve onto the ABS threads to form a seal.
Bill
billpherigo is offline   Reply With Quote
black, black tank, drain, leak, tank
