Old 05-28-2014, 10:18 AM   #1
Leaks from slide
We have a new Legacy 340 KP. I love it except that we have a leak only when the slide is in. The carpet is wet in a perfect square under the back edge of the wall slide in the bedroom. No signs of water coming from above. Any ideas?
PFurlow is offline   Reply With Quote
Old 08-17-2014, 09:10 AM   #2
We have the same problem
Minshall1 is offline   Reply With Quote
Old 01-06-2015, 09:37 PM   #3
ckmartin's Avatar
We have the same problem. Please let me know if you determine the problem.
ckmartin is offline   Reply With Quote
Old 01-06-2015, 10:10 PM   #4
Leak under slide
Yes they did fix it by using clear caulk down the seams and in the corner of the slide! They caulked all the way across the seam that runs from front to back on the side of the rv! Our bays are still leaking !
Old 01-06-2015, 10:52 PM   #5
Leak on carpet by bedroom slide -- found our solution
After further exploration we realized that we had a faulty coupling on the water line to the shower causing the wet carpet. My husband fixed it with a shark bite quick disconnect and all is well. Check the access panel below the bedroom under the TV to find these couplings.
leak, slide
