Old 11-03-2015, 10:43 PM   #1
Legacy Coax Routing Question
Soo.. More questions from me. Hoping someone who has a Legacy in hand can help me out.
I am going to pickup my Legacy next week which has a sat dome, hoping to get everything tested before picking up to fix any issues before I head back.
I know that the RV only has coax to each of the TV's, however I am unsure how this coax is routed. Does it go back to a central point or splitter block in the RV somewhere?
I'm hoping to get some Coax to HDMI converts, however I need to make sure the coax goes to a central point that I can put the Dish box and whatever else I am going to have hooked up.
The dealership is sending me pictures of where the coax comes from the rooftop dome tomorrow, but hoping to get a headstart on details where the rest of the coax comes to the other TV's (main room + bedroom at a minimum).
Also - do the tv's in the bunk have Coax, or just AV inputs?
doofoo is offline   Reply With Quote
Old 11-04-2015, 07:52 AM   #2
David29829
The TVs in the bunks are only DVD players...
david29829 is offline   Reply With Quote
Old 11-04-2015, 07:53 AM   #3
That's fine, I'm sure my daughter will be fine watching all her movies.
I'm more curious about the routing of the other coax lines.
2015 Forest River Legacy + 2020 Jeep Wrangler Rubicon TOAD
Old 11-04-2015, 07:01 PM   #4
Does anyone know where the coax that is on the main galley TV runs back to? Is it in the cabinet across from it on the switcher box? I'm trying to figure out how to setup a coax to hdmi or wireless hdmi converter for when I pickup the coach.
Want to be able to test the dish dome before I head off.
Old 11-04-2015, 07:35 PM   #5
7 Year Class A RV'er
On the 360RB, the TV is on a cabinet by the door, above the cabinet where the switch box and DVD player are located. If you look in the cabinet, the switch for the electric bunk is located in the top section. Remove the two screws (square head) and pull out the up/down switch. In the cavity behind it, you should see the coax cables running to and from the switch box routed in the vertical chase. Hope that helps some.
2015 Legacy SR340 360RB
