Originally Posted by conceptumator
Anyone have a clue how to remove the small glass lens on the ceiling mounted LED lights? I have one LED that is a lot dimmer that I think I need to replace or may be loose? Thanks.
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Hi replaced one in my 2015 v lite that is recessed in the ceiling. I had dealer order new light fixture from FR. I removed the 3 small screws that holds the fixture to the ceiling. Then pull down on the fixture. Watch out for the spring loaded brackets on the side of the light fixture as you pull it out of the ceiling.
If not careful you will find out how the mouse feels when the spring gets you.
With that said I had the lights off to the fixture I was removing no power. Cut the 2 Leeds after the crimped wire nuts close to the light fixture. Striped the wires back and wire nutted and taped the wires together made sure polarity was right and the light came on. Put back in ceiling very carefully two days later my finger stopped hurting.
very good rup goldberg mad:
hope this helps Tim
